Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: [Metal lathe] Indexing plate and cranck
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I needed something to index the spindle of my metal lathe, and I decided to build it, adding the crank feature. I wanted something not too much intrusive and that would be quickly mounted / unmounted as needed.
    Here is what I came up with :
    And here is how I did it :
    First the plate, continuing on my idea to source metal in the kitchen utensils, it is made from an induction interface plate. I initially thought it would have been made of plain stainless steel, but I discovered when drilling through it that it is actually principally made of aluminum, coated with stainless steel sheets on both sides. Anyway, this is good enough for me, it is 5mm thick.
    The shaft is turned out of aluminum round stock, and will be inserted in the spindle (21 mm on that side).
    The shaft is cut at 45° using the table saw. Wood cutting tools work well for aluminum.
    I don't remember who gave me this idea for locking the shaft in the spindle, I think it's here, maybe Paul Jones.
    It works very well and is really much easier to make than an expending system.
    The plate is screwed on the shoulders of the shaft.
    On the right you can see the beveled bottom part of the shaft. The inside bore is threaded and a piece of threaded rod will be used to pull it and lock it.
    For drilling accurately the indexing holes, I drew a two pieces template with my
    CAD software.
    It was initially planned only to be a template but I left it glued on the plate actually and varnished it to protect it from dirt.
    The crank knob, wood turned out of beech. I inserted a brass sleeve in it to ease the rotation of the knob around the screw.
    Finished Verso. The brass pin will be inserted in a small block of steel screwed on the lathe body.
    The tip is threaded M4 and the shaft has a 5mm diameter.
    Finished Recto :
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 30 Users Say Thank You to Christophe Mineau For This Useful Post:
    angusga (Mar 6, 2024), Biggus1942 (Oct 13, 2022), black joke19 (Aug 21, 2021), bobs409 (Jan 29, 2017), BrianW (Jan 16, 2020), Bullet500 (Mar 2, 2024), C-Bag (Apr 8, 2016), clydeman (Feb 4, 2020), Dollar Bill (Oct 21, 2023), flyfr8rs (Mar 26, 2024), garage nut (Dec 5, 2017), goonergord (Nov 2, 2023), Guy Marsden (Mar 6, 2024), hemmjo (Oct 21, 2023), high-side (Jan 17, 2020), hobbymax (Mar 2, 2024), jeanalvitre (Apr 16, 2016), johncg (Oct 22, 2023), Jon (Apr 8, 2016), lazarus (Jun 3, 2016), Metallurg33 (Apr 28, 2018), Miloslav (Oct 12, 2022), mr mikey (Oct 13, 2022), Philip Davies (Mar 4, 2024), PJs (Apr 8, 2016), Rangi (Apr 15, 2016), rctoywizard (Apr 8, 2016), sossol (Jan 16, 2020), tonyfoale (Mar 2, 2024), uv8452 (Oct 21, 2023)
    California, central coast
    C-Bag's Tools
    great project, great documentation!
    I feel another "tool of the week" coming on........
  4. The Following 2 Users Say Thank You to C-Bag For This Useful Post:
    bobs409 (Feb 18, 2018), Christophe Mineau (Apr 9, 2016)
    Dec 2015
    North central Missouri
    sking0369's Tools
    Nice work there but I'm not understanding what the shaft cut at 45 is for?
  6. The Following User Says Thank You to sking0369 For This Useful Post:
    Dec 2015
    Groton NH USA
    very nice job. I like it . thanks
  8. The Following User Says Thank You to rctoywizard For This Useful Post:
    Thanks Christophe Mineau! We've added your Indexing Plate and Crank to our Lathe Accessories category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  10. The Following User Says Thank You to DIYer For This Useful Post:
  11. #6
    Supporting Member scrdmgl's Avatar
    Oct 2013
    Toronto, Ontario, Canada
    scrdmgl's Tools
    The cut at 45 Deg., allows the short piece to slide when the bolt at the end is tightened and locks to the spindle ID holding the whole assembly in place. Simple and effective.
  12. The Following 3 Users Say Thank You to scrdmgl For This Useful Post:
    Christophe Mineau (Apr 9, 2016), Paul Jones (Apr 10, 2016), Philip Davies (Mar 4, 2024)
  13. #7
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice Job Christophe! Very cool to re-use the induction plate. Really like your protected template with the Octagon and Hexagon for an easy visual from the work side!! Great pictures and docs as well! Thanks for sharing a great build. ~PJ
    Mark Twain
  14. #8
    Dec 2013
    Florida
    rossbotics's Tools
    Hi christophe
    Good work buddy, I'm assuming you have a milling attachment on your lathe ? Are you making camshafts ? Crank Shafts ? Mr. Curiosity here LOL.
    Anyway great write up & Doc., I'm curious as to what was your main concern for making an indexing plate for your lathe,
    Nice Job
    Doug
    Comments are always welcome
    Doug
  15. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Apr 11, 2016)
  16. #9
    Jul 2014
    France, Brittany !
    Quote Originally Posted by rossbotics View Post
    Hi christophe
    Nice Job
    Doug
    Hi Doug, thanks for the kind words !
    Actually, more than the indexing feature, I needed the locking feature, especially for side drilling.
    (See the other topic)
    Example :
    Attachment 9890
    But Yes, I often do some small milling or grinding with my Dremel attachment, and I have recently purchased a small rooter that I wish to install on the lathe, probably in my milling square to get a Z axis.
    I want to use it also for sharpening or grinding some conical reamer for woodwind instrument making.
    Cheers !
    Cheers !
    Christophe
  17. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    PJs (Apr 11, 2016)
  18. #10
    Jul 2014
    France, Brittany !
    Quote Originally Posted by scrdmgl View Post
    Yes, that's exactly it, quick and easy solution !
    Cheers !
    Christophe
  19. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    PJs (Apr 11, 2016)
