Results 1 to 7 of 7
Thread: [Woodwind] Tone hole Cutter
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi !
    Here is a very specific tool made for shaping the top of a tone hole chimney.
    This is for tone holes that will be covered by a key. It is crucial that the pad of the key has a neat contact with the wood in order to avoid any leakage.
    The contact surface is actually reduced to a single ring if the tone hole has a slightly spherical top.
    Here is what we want to obtain :
    And here is how it is done :
    First, a guiding pin is turned down, given the diameter of the tone hole.
    And then a custom ground shaping tool is used to cut the spherical shape of what will be the cutting edge.
    Then I use my milling attachment to drill 6 transversal flat bottom holes with a small carbide end mill cutter.
    This will form cutting teeth
    Then I use a cutting disk on a Dremel to grind down the back of each tooth.
    Here I'm using my transversal drilling attachment on the lathe with this tool.
    Close up
    Finished Job
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 15 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (Feb 1, 2019), estrizhak (May 25, 2022), greyhoundollie (Oct 17, 2018), Home-PC (May 23, 2022), Jon (Jun 19, 2018), Philip Davies (Jan 1, 2024), PJs (Jun 21, 2018), Ralphxyz (Jan 8, 2024), rlm98253 (Jun 19, 2018), rossbotics (Jun 19, 2018), Seedtick (Jun 19, 2018), sossol (Oct 30, 2020), thevillageinn (Jun 21, 2018), Tonyg (Nov 3, 2020), volodar (Jun 20, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Looks like it worked !
    Doug
    Comments are always welcome
    Doug
    Dec 2016
    Ralphxyz's Tools
    WOW, thanks for all of your post, fascinating work.
    Ralph
    Thanks Christophe Mineau! We've added your Tone Hole Cutter to our Woodworking category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    PG1
    PG1 is offline
    May 2017
    Hi Christophe,
    very nice toolmaking. I plan to make a similar spotfacing tool with a 1.5mm guide pin, to uniform primer flash holes on cartridge cases. The commercial ones are the wrong shape -- just a #2 center drill in a holder-- and can thin the case too much.
    Is there a description of the milling attachment on your website?
    Paul
    Jul 2014
    France, Brittany !
    Quote Originally Posted by PG1 View Post
    Hi Christophe,
    Paul
    Hi Paul,
    Not on my web site, but here on my, yes:
    http://www.homemadetools.net/forum/h...1321#post93470
    Cheers !
    Christophe
  8. #7
    Aug 2020
    Basically, a spot facing tool.
