Remove advertisements
Results 1 to 9 of 9
Thread: 1-3 Ton Shop Hoist
    Carlos B's Avatar
    Canada
    Carlos B's Tools
    1-3 Ton Shop Hoist
    So it has been a while since I have built anything worthy of posting, but I just completed a hoist for the ventilated shop space and it might be of interest for some here. The first picture is my initial drawing, based on the materials I had available. It changed as heavier material became available.
    My trolley and chain hoist are both 1 ton but the I beam and mounting can except up to a 3 ton trolley and hoist, if the need arises. It was a quick project that generated lots of pictures. You can see the full build here Hobby Workshop Projects: workshop hoist.
    The end assemblies ready for welding.
    The welding set-up.
    Bolted in place.
    The completed hoist.
    In it's stored position.
    From a popular rap: "If time is money then I need a loan."
    Carlos B, http://www.hobbyworkshopprojects.com/
  2. The Following 6 Users Say Thank You to Carlos B For This Useful Post:
    Captn Roy (06-21-2018), Jon (06-19-2018), NortonDommi (06-20-2018), PJs (06-21-2018), Seedtick (06-21-2018), sossol (06-20-2018)
    Content Editor DIYer's Avatar
    Thanks Carlos B! We've added your Shop Hoist to our Hoists category,
    as well as to your builder page: Carlos B's Homemade Tools. Your receipt:
    Carlos B's Avatar
    Canada
    Carlos B's Tools
    Thanks DIYer.
    So I pulled my lawn tractor into the shop for some maintenance and try out the hoist. With the cutting deck it comes in close to 700 lbs, still only 1/3 the capacity of the hoist. Here's a picture.
  5. The Following User Says Thank You to Carlos B For This Useful Post:
    PJs (06-21-2018)
    Jun 2018
    SHOP HOIST
    Quote Originally Posted by Carlos B View Post
    Thanks DIYer.
    I like the hoist. I own a 56 ford f100 pickup and it will need disassembly and this would be useful.
    Oct 2013
    Eastern Townships, Quebec, Canada, Earth.
    Hi Carlos B,
    You did a fine job on that hoist, nice solid welds. Your install pulls everything together nice. I'd say you've got yourself a nice shop coming together also. That hoist is going to be a very useful tool for some time I'm sure. I've been looking for some similar design ideas and yours is very inspiring. Clean and solid. I'll bet that lawn tractor lift didn't even make it creak. Hehee. Very good work Carlos, Thanks for Sharing and enjoy your fine Hoist.
    Ray R.
    Carlos B's Avatar
    Canada
    Carlos B's Tools
    Thanks TrickieDickie, good luck with your disassembly, yes this should help, I have a couple of mobile hoists, they have there use but for many jobs they tend to be in the way.
  9. #7
    Carlos B's Avatar
    Canada
    Carlos B's Tools
    Thanks for the enthusiasm Ray R., good luck with yours. Yes your right very solid, not a sound when the full weight of the tractor went on it ha ha.
  10. The Following User Says Thank You to Carlos B For This Useful Post:
    PJs (06-21-2018)
  11. #8
    PJs
    PJs is offline
    PJs's Avatar
    Sep 2014
    Northern CA
    PJs's Tools
    Well designed and executed hoist Carlos B! Your write up on your blog has good details as I wondered how the beams were anchored on the floor.
    Great job and post, thanks for sharing with us.
    PJ
    Mark Twain
  12. The Following User Says Thank You to PJs For This Useful Post:
    Paul Jones (06-24-2018)
  13. #9
    Carlos B's Avatar
    Canada
    Carlos B's Tools
    Thanks PJs, I guess you read the ventilated shop build thread. Yes I pulled two patio stones dug down 5' (below frost [most of the time ] here) through part of a broken patio stone in the bottom, lined up my post and filled the hole with concrete. The shaped patio stone you see around the post is the top of the pour.
    Post your reply!
  14. The Following 2 Users Say Thank You to Carlos B For This Useful Post:
    Paul Jones (06-24-2018), PJs (06-22-2018)
