Remove advertisements
Results 1 to 8 of 8
Thread: 10 Watt solar panel mounting bracket.
    Captainleeward's Avatar
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    10 Watt Articulating solar panel mounting bracket.
    10 Watt solar panel mounting bracket. made from 1''x 1/16 " square tubing. 1 1/2 " x 1/8 " angle steel and 1 1/2" x 1/8" bar
    Solar panel 10 watt $25.00 incl ship keeps a marine battery charged up.
    10 Watt solar panel mounting bracket.-p6180003.jpg10 Watt solar panel mounting bracket.-p6180004.jpg10 Watt solar panel mounting bracket.-p6180005.jpg
  2. The Following 3 Users Say Thank You to Captainleeward For This Useful Post:
    PJs (06-21-2018), rossbotics (06-19-2018), Seedtick (06-19-2018)
    Content Editor DIYer's Avatar
    Thanks Captainleeward! We've added your Solar Panel Bracket to our Miscellaneous category,
    Ralphxyz's Avatar
    Dec 2016
    Ralphxyz's Tools
    "10 Watt articulating" looks fixed to me I don't see any articulation.
    Ralph
    Jul 2014
    Yes Ralph. the main shaft square tube rotates on both axis from where the bolts are.
    Ralphxyz's Avatar
    Dec 2016
    Ralphxyz's Tools
    I'll have to take your word on it, I cannot see it.
    I can see where it could tip front to back on the narrow access but do not see any motors or is it tipped by hand?
    Nice build by the way, looks substantial.
    Ralph
    Jul 2014
    Hi Ralph, Thanks, yea its just tipped by hand after I loosen the nut/bolts.
    I will be moving it from time to time to better point it at the sun . Cheers.
  8. The Following User Says Thank You to Captainleeward For This Useful Post:
    Paul Jones (06-20-2018)
  9. #7
    Ralphxyz's Avatar
    Dec 2016
    Ralphxyz's Tools
    re: "I will be moving it from time to time to better point it at the sun"
    Just add to your list of things to: Arduino sun tracking and motor control and put a couple of motors.
    Ralph
  10. #8
    mklotz mklotz's Avatar
    When I was a kid I built a solar tracker for a grade school science show. It was intended to be an electromechanical sundial but I never finished it.
    Imagine two small solar cells separated by an opaque vane (mine was made from tin can metal). This assembly sits on a platform capable of rotating about a vertical axis. A small DC motor can drive the rotating platform via a friction drive. The output from the solar cells power the motor and make the platform rotate.
    When the vane is pointing at the sun, the cells are illuminated equally and no net power is delivered to the motor. When the vane is not pointing at the sun, one cell is generating more power than the other and the motor drives the assembly until both cells are illuminated equally.
    My device is long gone but a net search turns up this version...
    Much more sophisticated construction than mine but the concept is exactly the same. Add a scale around the base and a pointer on the table and you have a sundial to tell the time with no complex geometry to lay out the calibrations.
    No "steenkin' computers" needed.
    Post your reply!
    Home Shop Freeware
  11. The Following User Says Thank You to mklotz For This Useful Post:
    Jon (06-21-2018)
