23 Best Homemade Tools from MadModder.net
The excellent forum at MadModder.net creates some very useful homemade tool builds.
MadModder is currently #13 on our list of homemade tools sites, with 218 homemade tools build by MadModder.net members (to see them all, check out: 218 homemade tools built by MadModder.net members).
Here's our pick of the 23 best homemade tools from the MadModder.net forum:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/helical-milling-device"><img src="/uploads/137190/helical-milling-device.jpeg" alt="Helical Milling Device"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/helical-milling-device">Helical Milling Device</a>
<span> by <a href="/builder/John+Hill_2">John Hill</a></span>
</div>
<div class="tags">tags: <a href="/tag/milling">milling</a>, <a href="/tag/mill">mill</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/circle-cutting-machine"><img src="/uploads/137226/circle-cutting-machine.jpeg" alt="Circle Cutting Machine"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/circle-cutting-machine">Circle Cutting Machine</a>
<span> by <a href="/builder/petertheterrible">petertheterrible</a></span>
</div>
<div class="tags">tags: <a href="/tag/circle">circle</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/light-box-8"><img src="/uploads/110124/light-box-8.jpeg" alt="Light Box"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/light-box-8">Light Box</a>
<span> by <a href="/builder/kwackers">kwackers</a></span>
</div>
<div class="tags">tags: <a href="/tag/light">light</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/machined-nutcracker"><img src="/uploads/108873/machined-nutcracker.png" alt="Machined Nutcracker"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/machined-nutcracker">Machined Nutcracker</a>
<span> by <a href="/builder/rdhem2">rdhem2</a></span>
</div>
<div class="tags">tags: <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/nutcracker">nutcracker</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/rotary-table-3"><img src="/uploads/108645/rotary-table-3.jpeg" alt="Rotary Table"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/rotary-table-3">Rotary Table</a>
<span> by <a href="/builder/NormanV">NormanV</a></span>
</div>
<div class="tags">tags: <a href="/tag/rotary-table">rotary table</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/internalexternal-threading-tool"><img src="/uploads/8229/internalexternal-threading-tool.jpeg" alt="Internal/External Threading Tool"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/internalexternal-threading-tool">Internal/External Threading Tool</a>
<span> by <a href="/builder/fatal-exception">fatal-exception</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/threading">threading</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/woodworking-awl"><img src="/uploads/6729/woodworking-awl.jpeg" alt="Woodworking Awl"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/woodworking-awl">Woodworking Awl</a>
<span> by <a href="/builder/adamriley">adamriley</a></span>
</div>
<div class="tags">tags: <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/awl">awl</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/120mm-rotary-table"><img src="/uploads/10373/120mm-rotary-table.jpeg" alt="120mm Rotary Table"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/120mm-rotary-table">120mm Rotary Table</a>
<span> by <a href="/builder/arnoldb">arnoldb</a></span>
</div>
<div class="tags">tags: <a href="/tag/mill">mill</a>, <a href="/tag/rotary-table">rotary table</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/tool-and-cutter-grinder"><img src="/uploads/15188/tool-and-cutter-grinder.jpeg" alt="Tool and Cutter Grinder"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/tool-and-cutter-grinder">Tool and Cutter Grinder</a>
<span> by <a href="/builder/cfellows">cfellows</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinder">grinder</a>, <a href="/tag/tool">tool</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/lens-spanner"><img src="/uploads/108825/lens-spanner.jpeg" alt="Lens Spanner"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/lens-spanner">Lens Spanner</a>
<span> by <a href="/builder/modeldozer">modeldozer</a></span>
</div>
<div class="tags">tags: <a href="/tag/wrench">wrench</a>, <a href="/tag/spanner">spanner</a>, <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/pin-wrench">pin wrench</a>, <a href="/tag/photography">photography</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/headstock-dividing-attachment"><img src="/uploads/108845/headstock-dividing-attachment.jpeg" alt="Headstock Dividing Attachment"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/headstock-dividing-attachment">Headstock Dividing Attachment</a>
<span> by <a href="/builder/PeterE">PeterE</a></span>
</div>
<div class="tags">tags: <a href="/tag/divider">divider</a>, <a href="/tag/indexing-unit">indexing unit</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/mini-turntable"><img src="/uploads/108793/mini-turntable.jpeg" alt="Mini Turntable"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/mini-turntable">Mini Turntable</a>
<span> by <a href="/builder/Bangkok+Mick">Bangkok Mick</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/drill-press">drill press</a>, <a href="/tag/turntable">turntable</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/beer-keg-casting-furnace"><img src="/uploads/108773/beer-keg-casting-furnace.jpeg" alt="Beer Keg Casting Furnace"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/beer-keg-casting-furnace">Beer Keg Casting Furnace</a>
<span> by <a href="/builder/tom+osselton">tom osselton</a></span>
</div>
<div class="tags">tags: <a href="/tag/casting">casting</a>, <a href="/tag/furnace">furnace</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/boring-table"><img src="/uploads/108765/boring-table.jpeg" alt="Boring Table"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/boring-table">Boring Table</a>
<span> by <a href="/builder/vtsteam">vtsteam</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/table">table</a>, <a href="/tag/boring">boring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/spotting-tool"><img src="/uploads/108841/spotting-tool.jpeg" alt="Spotting Tool"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/spotting-tool">Spotting Tool</a>
</div>
<div class="tags">tags: <a href="/tag/centering">centering</a>, <a href="/tag/qctp">QCTP</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/engraving-pantograph"><img src="/uploads/108661/engraving-pantograph.jpeg" alt="Engraving Pantograph"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/engraving-pantograph">Engraving Pantograph</a>
<span> by <a href="/builder/sorveltaja">sorveltaja</a></span>
</div>
<div class="tags">tags: <a href="/tag/engraver">engraver</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/milling-machine-6"><img src="/uploads/108685/milling-machine-6.jpeg" alt="Milling Machine"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/milling-machine-6">Milling Machine</a>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/die-filer"><img src="/uploads/109469/die-filer.jpeg" alt="Die Filer"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/die-filer">Die Filer</a>
<span> by <a href="/builder/CallMeAl">CallMeAl</a></span>
</div>
<div class="tags">tags: <a href="/tag/file">file</a>, <a href="/tag/die">die</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/low-profile-clamps-2"><img src="/uploads/109952/low-profile-clamps-2.jpeg" alt="Low Profile Clamps"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/low-profile-clamps-2">Low Profile Clamps</a>
</div>
<div class="tags">tags: <a href="/tag/clamp">clamp</a>, <a href="/tag/mill">mill</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/knurling-tool-6"><img src="/uploads/110652/knurling-tool-6.jpeg" alt="Knurling Tool"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/knurling-tool-6">Knurling Tool</a>
<span> by <a href="/builder/geroli">geroli</a></span>
</div>
<div class="tags">tags: <a href="/tag/knurling">knurling</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/uv-led-exposure-unit"><img src="/uploads/110612/uv-led-exposure-unit.jpeg" alt="UV LED Exposure Unit"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/uv-led-exposure-unit">UV LED Exposure Unit</a>
<span> by <a href="/builder/raynerd">raynerd</a></span>
</div>
<div class="tags">tags: <a href="/tag/pcb">PCB</a>, <a href="/tag/etch">etch</a>, <a href="/tag/etching">etching</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/tubing-bender-19"><img src="/uploads/111698/tubing-bender-19.jpeg" alt="Tubing Bender"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/tubing-bender-19">Tubing Bender</a>
<span> by <a href="/builder/Divided+he+ad">Divided he ad</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/pinch-rollers"><img src="/uploads/137166/pinch-rollers.jpeg" alt="Pinch Rollers"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/pinch-rollers">Pinch Rollers</a>
<span> by <a href="/builder/Andrew+Wildman">Andrew Wildman</a></span>
</div>
<div class="tags">tags: <a href="/tag/slip-roller">slip roller</a></div>
</div>
</div>
</div>
