Remove advertisements
Results 1 to 6 of 6
Thread: 3.5" live center
    Frank S's Avatar
    3.5" live center
    today I needed to make a larger live center for a project that is coming up
    First I drilled the piece of round stock cut off of a shaft that came out of a cotton gin to 2 " then bored it toe 2.8346 72 mm to accept a pair of 6207 CZ bearings then I machined the cone
    next I made a mandrel from a piece of 1.75" hydraulic cylinder rod
  2. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    Jon (05-22-2018), olderdan (05-22-2018), Paul Jones (05-22-2018), PJs (08-27-2018), Seedtick (05-22-2018), Tuomas (05-22-2018)
    Frank S's Avatar
    I purposely made the mandrel to be easily removed for use in other things of a larger live center cone if need be
    pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    I worked at a place that made live centers for the paper industry, or whatever people wanted really gigantic centers for. The big ones were about 6 feet tall standing on end. I forget how many tons they were rated for but it was a lot. I just remember it being some ridiculous amount.
    Sep 2012
    Hinchinbrook QLD
    Frank,
    Did you consider using a thrust bearing?
    Frank S's Avatar
    12 bolts I had 2 of the 6207s I could swap them out for an angular contact but it would hardly be needed since the size of the bearing are so large 35 mm ID 72 MM OD 14 mm thick with 12 11.1 mm balls No more thrust load that could possibly be placed on them by the tails stock screw there really is no need for a thrust bearing or even an angular contact they have a radial capacity of 31022.750n per bearing and if it were even possible to exert as much as 2224n the bearing life would be 7915 hrs at 1200 RPM
  7. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    12bolts (05-23-2018), PJs (08-27-2018)
    Content Editor DIYer's Avatar
    Thanks Frank S! We've added your Live Center to our Machining category,
    Post your reply!
