Results 1 to 10 of 13
Thread: 4-station tailstock turret
    Mar 2018
    New England, USA
    threesixesinarow's Tools
    This is an attachment for the bigger tailstock on my watchmaker lathe. I mostly copied a Schaublin accessory, but added features from a more complete Lorch turret tailstock.
    It just advances by hand but the stop shaft rotates with the turret, and fully retracting the ram disengages the indexing pin which then resets with a spring when it advances.
    The sockets are 1/2”.
    4-station tailstock turret-turret02_tailstockfront.jpg 4-station tailstock turret-turret03_tailstockrear.jpg
    4-station tailstock turret-turret04_indexlever.jpg 4-station tailstock turret-turret05_drawing.png
    4-station tailstock turret-turret06_schaublin.jpg 4-station tailstock turret-turret07_lorchtailstock.gif
  2. The Following 10 Users Say Thank You to threesixesinarow For This Useful Post:
    high-side (Apr 24, 2019), Jon (Nov 22, 2018), LMMasterMariner (Nov 24, 2018), Maszynotwór (Mar 13, 2019), old_toolmaker (Mar 11, 2019), Paul Jones (Nov 23, 2018), PJs (Nov 24, 2018), rossbotics (Nov 24, 2018), Seedtick (Nov 22, 2018), Toolmaker51 (Nov 22, 2018)
    Thanks threesixesinarow! We've added your Tailstock Turret to our Lathe Accessories category,
    Dec 2013
    Florida
    rossbotics's Tools
    Nice work, good job, came out well
    Doug
    Comments are always welcome
    Doug
    Mar 2018
    New England, USA
    Thanks, Doug - I’m still learning how to set it up and use it, but it works, and hopefully it’ll be durable. I made the stop shaft journal and bearing tapered so they can be adjusted, and a lot of the parts in it are hardened, including drill bushing inserts in the indexing holes.
  6. The Following User Says Thank You to threesixesinarow For This Useful Post:
    Paul Jones (Nov 25, 2018)
    Mar 2018
    New England, USA
    A Boley I hadn’t seen before, with a more compact stop arrangement.
    From Watchmakers Lathes at lathes.co.uk
    Walkman's Avatar
    Sep 2018
    Very slick setup. Guess I'll have to put on the thinking cap and see if I can't round up something like this on the old Grizzly I've got.
    Nice job!
    Walkman
  9. #7
    Mar 2018
    New England, USA
    Thanks, Walkman,
    mars-red has a couple videos on youtube showing the construction of a very nice 6-station turret with the same kind of flat design, on about the same scale.
    It’s a good choice there, and here because it doesn’t take much extra room lengthwise - my lathe is only something like 5 or 6” between centers. It’s less flexible, too, the ram on mine can retract completely and its front end is very close to the tool shank sockets.
    Even with four stations it’s a tight fits for tools, though, and some tools and combinations won’t work at all.
  10. #8
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    threesixesinarow,
    You have done a very nice looking job on the turret! You are also a very productive builder!
    Keep up the good work.
    Dick
    Links to some of my plans:
  11. #9
    Mar 2018
    New England, USA
    Thanks, Dick,
    It’s a few years old. It’s nice to use even just with a center drill and a dead center.
    I considered getting a cheap morse taper tailstock turret for my mini lathe for a long time but hesitated because of the combination of their big overhang with the unreliable tailstock, as well as the extra steps for indexing the turret and stops. Now that I have a better tailstock for it, I plan to rebore the old one and convert it to a simple lever feed like what’s on a Taig but I’m still not sure whether it’ll be up to the task.
  12. #10
    Dec 2017
    Cape Coral, FL
    threesixesinarow
    How do you intend to set the tailstock up for boring to ensure perfect alignment?
    Dick
