Results 1 to 10 of 11
Thread: 41 interesting vise patents - drawings
    Some vise patent pickins using the complex but excellent advanced patent search at USPTO.gov. An example query for a search like this, entered into the advanced search box here:
    CCL/269/$ AND APT/1 AND ISD/9/10/2008->9/10/2018 AND (TTL/vice OR TTL/vise)
    In order:
    CCL/269/$ - US patent classification class 269: Work Holders (the class most likely to contain vise patents)
    APT/1 - utility patents only (this eliminates design patent results)
    ISD/9/10/2008->9/10/2018 - patent issue date for the past decade (ISD limits my search to only issued patents, and not applications)
    TTL/vise OR TTL/vice - two common spellings of vise
    For a larger search, just expand the date range, or add queries like "clamp" or "work holding". Some curated results below; click on each for the full patent:
    Multi-Functional Vise Base
    Quick Release Vise
    Precision Leveling Vise
    Vise Pads for Accurate Work Alignment
    Flexible Vise Jaw
    Centric Clamping Vise
    Pressure Adjusting Vise Apparatus
    Torque Measuring Vise
    Pocket Hole Drill Guide Fixture
    Integrated Foot Vise and Wrench
    Portable Dual Vise for Horseshoes
    Modular Vise System
    Work Table with Integrated Vise
    Micro-Adjustable Parallel Bench Vise
    Vise Carrying Device
    Cam-Activated Bench Vise
    Self-Centering Dual Direction Vise
    Five Axis Machine Vise
    Machine Vise Quick Locking System
    Quick Release Moveable Jaw Apparatus
    Pipe Vise Stand
    Double Clamp Vise
    Bandsaw Vise
    Multiple Vise System
    Pipe Bender Vise
    Quick Change Vise Jaws
    Quick Action Woodworking Vise
    Quick Release Bench Vise
    Multiple Jaw Vise
    Portable Vise
    High Density Fixture Vise
    Locking Vise with Slide Member
    Carving Vise
    Power-Actuated Vise Apparatus
    Sine Vise
    Intensified Machinist Vise
    Chain Vise Pipe Clamp
    Quick Release Vise
    Vise or Clamp Attachment
    Combination Vise and Clamp
    Self-Adjusting Locking Vise Grip
  2. The Following 9 Users Say Thank You to Jon For This Useful Post:
    dubbby (Mar 16, 2020), high-side (Sep 19, 2018), LMMasterMariner (Sep 19, 2018), PJs (Sep 24, 2018), rossbotics (Sep 25, 2018), Seedtick (Sep 19, 2018), Toolmaker51 (Sep 19, 2018), uv8452 (Jun 26, 2021), volodar (Sep 20, 2018)
    bruce.desertrat's Tools
    I own one of those Portable Vises, basically a steel plate with appropriate cutouts to hold dimensional lumber for quick cross-cutting. It occasionally comes in handy when building stuff out in the yard, and if all you have is a circ saw to use it's definitely better than an improvised sawhorse of some sort.
  4. The Following 2 Users Say Thank You to bruce.desertrat For This Useful Post:
    philipUsesWood&Brass (Sep 25, 2018), Toolmaker51 (Sep 25, 2018)
    Forgive poor Jon, and all his vises.
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    TSiArt (Sep 20, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    I was thinking Doug might have a field day here. Overall, interesting patents and some looked familiar.
    Mark Twain
    Dec 2013
    Florida
    rossbotics's Tools
    You're right PJs
    Some of those creatures look familiar don't they
    Doug
    Comments are always welcome
    Doug
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by rossbotics View Post
    You're right PJs
    Doug
    Yes they do and some are quite ingenious and complex. That Locking vise with slide member although a complex and likely an expensive build seems very versatile. The fairly complex, 3 jaw conical lock/release (fig. 7) for the slider is well done and could be adapted to other systems. Adding the optional multiple lobe cams is also a cool idea, imho.
    So Doug, do any strike your fancy for a "Next gen Doug build"?
    There is a beauty and simplicity to Patent drawings that lights my candle! Also forgot to Thank Jon for all the links in my previous post.
    PJ
    Mark Twain
  10. #7
    Quote Originally Posted by bruce.desertrat View Post
    Agreed Bruce; though I know these as plate vises. There are 2 varieties [at least what I have] sized for dimensional lumber and tube/ conduit/ pipe.
    Portable Vise
    Very handy when working alone. Handy enough on the ground, and worth effort hauling up scaffold, roof or mezzanine. Not a tough DIY project, piercing holes, triangles, squares & rectangles, long as profiles are somewhat smooth.
    I use one most often breaking down round stock with a portable bandsaw.
  11. #8
    I think I'm going to work on more posts like this. They're time-consuming to assemble, but probably more intellectually valid than most other GIF or short video style posts. On their face, that is - sometimes a cheesy GIF leads to a rewarding and technically valid conversation.
    Probably best themed by decade instead of "So-and-so many interesting...". For example: "Vise patents of the 1930s". Bookending the patents like that will allow me to review them in discrete chunks. The USPTO has an API that I might be able to use for quicker image retrieval too.
    Let me know if anyone has ideas, or is curious about specific types of tool patents.
  12. The Following 4 Users Say Thank You to Jon For This Useful Post:
    HobieDave (Mar 24, 2020), PJs (Oct 3, 2018), Toolmaker51 (Oct 3, 2018), uv8452 (Jun 26, 2021)
  13. #9
    I, for one enjoy patents. Especially when related to products I utilize in some manner.........So patents articles as you've generated already, are informative. For me an even greater benefit would be in the technique, maybe a 'checklist' of recommended & successful search avenues.
    My brake is a good example. Very little appears, even less starting from my usual point -brand name and trademark.
    So far, patent numbers and date info was not all that close to what I have. Kind of disappointing.
  14. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Oct 4, 2018)
  15. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    I agree Jon this type of post can generate discussion, but give insight to how a device evolves transforms and vectors over a period. It is a lot of work at times and have personally spent hours/days researching patent data bases. They are good for fleshing out ideas or seeing how a need can utilize a portion of design without re-inventing the wheel so to speak. Or, repair/restore an old tool which many of us here enjoy.
    An example of one from a while back started with a coffee table size book on patented suppressor technology from the 20' to the 70's I was loaned. Probably 300 pages and each patent inside also had the patents referenced within each, which led (rabbit holed) to some interesting finds in searches. Most of what I was looking for was around db levels, frequencies and various schemes as to how pressures are chamber, routed and dissipated...all which stem back to a couple of your posts on Artillery suppression systems.
    I have also collected all of Tesla's patents and refer to them a fair amount when kicking around new alt energy ideas or specific detail he worked out a 100+ years ago. His patents on his turbine still fascinates me for some of the detail that doesn't get translated in modern versions as well as his ground transmission system.
    If I think of any specifics I'll chime in but this vise posting is a great starting point, imho and followed several of the linked rabbit holes to good depth. You are pretty darned good at finding candles to light and I'm Always grateful to lean something new or old...and look forward to whatever comes forth.
    PJ
    Mark Twain
  16. The Following User Says Thank You to PJs For This Useful Post:
    Toolmaker51 (Oct 9, 2018)
