4way tool post
QC toolposts are all the rage now but, though I use one, I still find the venerable 4way style faster to use in many cases. I have a number of homemade 4ways, several of them dedicated to various jobs.
As an example, here's a general purpose one...
It has slots to take two conventional tools (typically a general purpose turning tool and a 45 deg chamfering tool) as well as holes that accommodate two sizes of boring bars.
On the other side is a cutoff tool permanently mounted to this 4way...
If you make your own tool post be sure to arrange things so the handle used to tighten the lockdown bolt points at a convenient angle out of your way - typically your 4 o'clock direction as you face the lathe.
The way I do it is to pin a chunk of hex to the lockdown bolt. A conical end is turned on this chunk. Then the bolt is assembled to the toolpost on the lathe and the bolt tightened with a wrench on the hex. Once a satisfactory tightness is reached, the 4 o'clock position on the cone is marked. Then the whole thing is disassembled and a hole drilled on the mark. The handle is then Loctited into this hole.
Thanks mklotz! We've added your Tool Post to our Tool Holders category,
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-tool-post-4">
<img src="/uploads/164981/homemade-tool-post-4.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-tool-post-4">Tool Post</a>
<span> by <a href="http://www.homemadetools.net/builder/mklotz_3">mklotz</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/tool-post'>tool post</a> </div>
</div>
</div>
</div>
Nice idea, I think I will revive my old tool post, its true it can be kept set up with the best seller tools you use the most.
I really like the built in parting tool and boring bar holders of yours.
Thanks !
Christophe
Thanks for good photos and clear explanations. I can apply this to my homemade mill/lathe as well as my Atlas.
Interesting to me as well, even 3 something years later. Getting use out of commercial 4-ways still, but would like to run off one custom made. Don't have CNC, but carving out one side for a rocker sounds like a good idea.
Is there a way? Well, a vise on a rotary table would, but I know another and w-aay easier.
And good utilization of hex geometry to set handle orientation, Mr. K. I usually use method common in gunsmithing, of space and threads per inch, being divisible by angles. Then face or create washer of correct thickness.
