Nice work!
Nice work!
Fantastic ! Same for me, I was about to ask how old it is....
You are a fine artist, really, congratulations !
Beautiful work buddy! Question....why is the motor mounted 90 degrees from the axis of rotation? Is there a right angle drive in the base? If so, why?
Quite a show stopper!! :clapping: The creative spoke forming was Terrific! A little confused about the drive and how the motor drives the twin roller chain and gears at right angles...conicals on the inside? Thanks for posting this beauty! ~PJ
Simply Outstanding!A work of art.
Another question: When you bent the spokes in the press did you simply rotate the cut plate by the same angle as the taper in the spokes?
Electric motor turns a hydraulic pump inside the saw base, hydraulic motor turns sprocket
When fabrication is near indistinguishable from castings; perfect execution and combination of form following function. That in it's self is a rare occurrence. Detailing in the early photos interesting enough; the final product is astounding.
Hola cmptree, si eso salió de un papel:aplausos:, congratulaciones una belleza de máquina, hasta pronto.
