Results 1 to 10 of 15
Thread: Band Saw fixture plate
    Dec 2016
    bobs409's Tools
    Lightbulb Band Saw fixture plate
    My latest creation is this fixture plate for a band saw. This allows you to cut small parts safely, even smaller than shown.
  2. The Following 36 Users Say Thank You to bobs409 For This Useful Post:
    Alan Purdy (Feb 12, 2019), Andyt (Feb 12, 2019), billd (Feb 11, 2019), Captainleeward (Feb 9, 2019), cogentia (Mar 11, 2021), davehc (Feb 12, 2019), GKK (Feb 17, 2019), high-side (Feb 11, 2019), Home-PC (Mar 10, 2021), jackhoying (Feb 11, 2019), janders1957 (Feb 12, 2019), jjr2001 (Feb 15, 2019), Jon (Feb 9, 2019), marksbug (Mar 10, 2021), melbakid (Mar 11, 2021), Midwestern640 (Sep 12, 2019), natie123 (Feb 11, 2019), Paul Jones (Feb 14, 2019), Peter Sanders (Feb 18, 2019), PJs (Feb 12, 2019), Rangi (Feb 25, 2019), rlm98253 (Aug 9, 2023), rossbotics (Feb 12, 2019), Saltfever (Feb 24, 2019), Scotsman Hosie (Feb 15, 2019), Sleykin (Mar 11, 2021), sossol (Feb 11, 2019), Soundguy.paul (Mar 11, 2021), steamingbill (Feb 11, 2019), Steved53 (Feb 12, 2019), tjarkheeres (Jul 1, 2020), Tonyg (Feb 12, 2019), Toolmaker51 (Feb 11, 2019), tooly (Apr 3, 2019), Tule (Feb 12, 2019), yves78 (Feb 11, 2019)
    Supporting Member jackhoying's Avatar
    Apr 2014
    Fort Loramie, Ohio
    jackhoying's Tools
    This is a real simple, but very well thought out fixture plate. I'll definitely be making something similar for my bandsaw.
    Thanks,
    Jack
  4. The Following User Says Thank You to jackhoying For This Useful Post:
    bobs409 (Feb 11, 2019)
    Aug 2018
    How do you handle 45 deg angle cuts?
    Nice job for 90 deg cuts and small parts, I am trying to re engineer my band saw into a mitering one like ellis saw.
    Dec 2016
    bobs409's Tools
    Quote Originally Posted by billd View Post
    Well that will still have to be invented. LOL This is of course only 90 degree cuts. I'm sure something with a 45 degree cut on the end could do it though...
    Marion, Iowa
    metric_taper's Tools
    I don't see anything in Bob's design that prevents the vise on the band saw from being moved to any angle of 0 to 45. Just put the other end of the square tube (leave one end square) in the vise, and cut it off to 45. Then it will be parallel to the blade cut. The threaded fixture holes and thumb wheel jack, will still hold the work piece.
    I really like this fixture idea.
    Thank you Bobs409!
  8. The Following User Says Thank You to metric_taper For This Useful Post:
    bobs409 (Feb 12, 2019)
    Capital idea in use of tubing for a base, for others C-channel is good too. Accomplishing miters, at least some, are possible with Bobs409 tool.
    The fixture is already in place, only need stops for locating material at positions other 90°. Extend range by widening plate between vise jaws. Builder could populate with more tapped holes as well.
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  11. #7
    yves78's Avatar
    Jan 2016
    Thanks ! I was looking for a solution for small parts, and I really like yours.
    Easy and efficient, I'll do it.
  12. The Following User Says Thank You to yves78 For This Useful Post:
  13. #8
    Dec 2013
    Florida
    rossbotics's Tools
    Great idea, thanks for sharing
    Doug
    Comments are always welcome
    Doug
  14. The Following User Says Thank You to rossbotics For This Useful Post:
  15. #9
    Aug 2016
    wizard69's Tools
    For angles use angle blocks, sine bars or whatever on top of the 2x3. Shouldn’t be a big deal for shallow angles steeper angles would benefit from a larger block. More mounting holes wouldn’t hurt either. All in all an excellent idea.
  16. The Following User Says Thank You to wizard69 For This Useful Post:
    bobs409 (Feb 15, 2019)
  17. #10
    Thanks bobs409! We've added your Bandsaw Fixture Plate to our Workholding category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
  18. The Following User Says Thank You to DIYer For This Useful Post:
