Simple tool for turning brake:
Thanks darkoford! We've added your Brake Turning Tool to our Brake category,
as well as to your builder page: darkoford's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-brake-turning-tool"> <img src="/uploads/202646/homemade-brake-turning-tool.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-brake-turning-tool">Brake Turning Tool</a> <span> by <a href="http://www.homemadetools.net/builder/darkoford">darkoford</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/brake'>brake</a>, <a href='http://www.homemadetools.net/tag/machining'>machining</a> </div> </div> </div> </div>
Genius! I wish I had thought of that. This morning I spent about 30mins tapping and reading my indicator to get the disc in the chuck perfect... Nice video, nice idea.
20+ years needed me to simplify the job. Practice while you are alive!
:beer:
When I first saw the tittle I thought someone might be restoring a vintage brake lathe like a Van Norman, Ammco, Barrett, Or possibly a Quick-way or Coats which I think were made by Van Norman
The adapter you made if it had been bored to fit a mandrel would be quite similar to those used on brake lathes since the beginning so good job
Single cutting disks is often done but can lead to the surfaces not being parallel to each other
Making or buying a twin cutter assembly is always optimal but hardly worth the expenditure in time materials or money for a one time run Many shope will no longer turn or true disks or drums due to liabilities and labor expense
great tool.
