Can anyone tell me if they think brass bushings would be sufficient to install in a 4 step pulley that I want to use as a speed reducer on an old drill press? It presently has the typical 2 (4 step pulleys) pulleys and single v belt on a vintage Delta DP220 drill press. I want to add the third pulley and use a 2 belt system to bring down the RPM's enough to use it on metal because it's a little too fast presently. Or, should I use bearings? Thanks in advance
