Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Building A Better Mousetrap
    Feb 2015
    Manitoba Man's Tools
    Good thinking. Good professor and good hydrodynamics at work
  2. The Following User Says Thank You to Manitoba Man For This Useful Post:
    rgsparber (Jul 22, 2019)
  3. #12
    Gromet's Avatar
    Apr 2019
    SE Pennsylvania, USA
    Third "page" is blank for me
    Gromit
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    You’re not missing much. It is my standard sign off “boiler plate”.
    Rick
    Rick
  5. #14
    jdurand's Tools
    Keep the water bottle out of the sun. When it heats up it will push out water overflowing the dish. Then at night it will suck in air, primed for the next day.
    Our 3 gallon chicken watering station can empty itself very quickly in the sun.
  6. #15
    Does anyone else have this problem? It works for me.
    Rick
    Problem solved...
    Apparently a recent Firefox update reset my selection of what to do if Firefox is redirected to a URL that points to a PDF. After resetting this option to "Preview in Firefox" everything works as it did before the update.
    I discovered this when I got the same blank screen when redirected to a PDF on an entirely different page. This generalized my focus away from HMT and onto the more general "Firefox doesn't know what to do when sent to a PDF" idea. From there a bit of searching quickly located the problem.
    For users who may be having the same problem here's the procedure I used in Firefox Quantum version 68.0.1...
    Click on the Options tab and scroll down to Applications
    Locate "Portable Document Format (PDF)" and right click on it
    Select the "Preview in Firefox" option
    Home Shop Freeware
  7. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Jon (Jul 21, 2019), rgsparber (Jul 22, 2019)
  8. #16
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I’m not sure why, but this has not been a problem. The water bottle has been in the sun for a few weeks now. I go through about 1.5 L per week. The highs are around 110F and the lows are around 80F. The pan is metal and covered in about 1/4 inch of water at all times.
    Rick
    Rick
