Results 1 to 10 of 12
Thread: Calculating the radius of a circular segment
    The law of cosines, apparently not well known, was used in a previous post...
    http://www.homemadetools.net/forum/s...-polygon-67853
    to good effect to solve a not uncommon shop problem.
    Here we use a somewhat more obscure theorem to unravel another shop problem.
    Suppose you have a circular segment like the figure APBXA in the illustration below. It could be a gear fragment, a key segment you want to reproduce, or even a flower bed you want to extend. How do you go about determining the radius of the circle from which the segment derives?
    The tool we'll use is the intersecting chords theorem. It says that, if two chords intersect inside a circle, their individual parts are mathematically related to each other. A full description, including a proof of the theorem, is here...
    https://en.wikipedia.org/wiki/Inters...chords_theorem
    From the intersecting chords theorem, we have:
    XP x XQ = XA x XB
    Define:
    c = AB ; c = chord length of segment
    h = XP ; h = "height" of segment
    which are things we can measure from the segment, then, substituting into the intersecting chords theorem, we have:
    (c/2)^2 = h x XQ
    which can be solved for XQ
    XQ = c^2/(4h)
    The diameter, PQ = PX + XQ and
    PX + XQ = h + c^2/(4h) = (4h^2 + c^2)/(4h)
    and the radius of the circle, CQ, is half this diameter
    r = CQ = (4h^2 + c^2)/(8h)
    Home Shop Freeware
  2. The Following 12 Users Say Thank You to mklotz For This Useful Post:
    12L14 (Jul 3, 2022), Frank S (May 28, 2018), high-side (Sep 4, 2020), Jon (May 28, 2018), kboy0076 (Oct 19, 2022), natie123 (Jun 18, 2018), PJs (May 29, 2018), rgsparber (Aug 20, 2020), rossbotics (May 30, 2018), Seedtick (May 28, 2018), Toolmaker51 (Aug 21, 2020), Tuomas (May 29, 2018)
    Supporting Member Imabass's Avatar
    Dec 2015
    Imabass's Tools
    Excellent. This is common problem for buying the correct fenders for motorcycle.
    Thanks mklotz! We've added your Circular Segment Radius Calculation Method to our Measuring and Marking category,
    Apr 2012
    NorCal
    Saltfever's Tools
    Excellent, Marv . . . keep them coming! Your timing is perfect . . . I need to extend the driveway. :-)
    The radius calculation here can also be used to find a circle that will pass through three (non-colinear) points.
    If you have the three points identified as A, B, and P in the diagram, the calculation will, as described, find the radius of the circle that passes through those points.
    Finding the center of that circle is trivial. Using the calculated radius, draw a circle around two of the points. One of the intersection points of those circles is the center of the circle passing through all three points. It should be obvious which it is but, if unsure, draw a circle around the remaining point; where all three circles intersect is the center.
    Home Shop Freeware
    Vermont
    Often needed for fire box to cook chamber on a smoker...
  8. #7
    Imabass, Saltfever and GreenSmoker
    Thanks for your comments indicating that this mathematical exercise has some real utility for you.
    So often, folks are completely put off by anything that even hints of math, that its utility is overlooked as they flee. Showing them that there are applications out there where it can help will encourage them to look a bit closer at the next offering.
    Home Shop Freeware
  9. The Following User Says Thank You to mklotz For This Useful Post:
  10. #8
    Tenn's Avatar
    Jul 2018
    middle Tennessee
    Well said, too often, in schools, random generic formulas ... with no practical application, confuses and frustrates otherwise willing learners. Same on the shopfloor. Often an example gives what otherwise seems like Egyptian hieroglyphs a plausible and useful application. I've had young students who said "I don't need school" change their mind when they actually saw how to apply a mathematical concept in real life. It makes all the difference in the world for many.
    You can't teach what you don't know and you can't give what you don't have. ~CF
  11. The Following 2 Users Say Thank You to Tenn For This Useful Post:
    high-side (Sep 4, 2020), Toolmaker51 (Aug 21, 2020)
  12. #9
    Vermont
    I have an excel file for this...no way to post it...any help...
  13. #10
    GreenSmoker - just added .xls as an acceptable forum file type upload. Try now.
