Not to what NYPD and FDNY told you but I believe their analogy may have been slightly off or more accurately incomplete. While the explosive source was in all probability a hairspray can or possibly multiples there of. It was unlikely the can was empty or near empty also the incinerator door was probably improperly latched or the locking mechanism was faulty, other wise the blast force should have been contained. That being said it is true older elevator doors were quite easily dislodged especially when the track and rollers became worn from years of use and many apt buildings did not have separate freight elevators to serve utility basements which would have had more robust doors
the propellant in hair spray cans used to contain propane quite volatile, a full can depending on size could equal a 1/4 stick of dynamite in explosive force.
