A Captured Ball Lip Tool
Have you ever wanted to put a ball bearing into a hole with enough clearance to freely move yet not fall out the bottom? A common method of doing this is to drill the hole through and then form tiny bumps at the opening. These bumps effectively reduce the diameter and capture the ball. The method presented here uses a modified carriage bolt, a nut, and a washer.
http://rick.sparber.org/CBLT.pdf
Thanks,
Rick
Rick,
Great idea and easy to do without fancy tools.
Thank you,
Paul
Thanks Rick! We've added your Captured Ball Lip Tool to our Miscellaneous category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/captured-ball-lip-tool"><img src="http://www.homemadetools.net/uploads/152232/captured-ball-lip-tool.png"/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/captured-ball-lip-tool">Captured Ball Lip Tool</a>
<span> by <a href="/builder/Rick+Sparber">Rick Sparber</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/bearing">bearing</a>, <a href="http://www.homemadetools.net/tag/hand-tools">hand tools</a></div>
</div>
</div>
</div>
