Results 1 to 7 of 7
Thread: Case Hardening Compound
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Just thought I would start a thread on this subject to see if I could find any better options:
    I'm currently using this compound from EKP tools:
    More details and a review here: Case Hardening Compound – glue-it.com
    What other options are there for case hardening?
  2. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    PJs (Apr 20, 2018)
    ChrisB257's Avatar
    Dec 2016
    ChrisB257's Tools
    I used to use "Kasenit" but found it no longer available. I landed on this site - https://www.travers.com/1lbcan-1-surface-hardning-compnd-kasenit/p/81-003-001/ - they do suggest an alternate option ( https://www.travers.com/steel-surfac.../p/81-003-201/ ). I saw from the available PDF ( https://www.travers.com/images/art/81-003-001_msds.pdf ) "Kasenit" was Sodium ferrocyanide - yellow prussate of soda! Na4 Fe(CN)6
    Hope this might help.
    Ain't technology great - until it goes wrong!
    The Old Man's Shop
  4. The Following User Says Thank You to ChrisB257 For This Useful Post:
    PJs (Apr 20, 2018)
    bruce.desertrat's Tools
    Chris (@clickspring) has explored this process in his Antikythera build, and got some quite decent hardening with just charcoal, salt and flour:
    Sounds much less toxic than mucking about sodium ferrocyanate! You DEFINITELY want good ventilation for that!)
    So far I think I'm enjoying his 'Antikythera Fragments' videos about re-inventing and exploring ancient technology as much as the mechanism build itself...
    While compounds for inducing carbon to mild steel have 'modernized', the physical element hasn't. Higher potential heat has deepened it, and service is offered by most any heat-treat plant commercially. But the process is still easily applied with minimal equipment.
    Historically, carburization was done in a fire pit. Parts were packed in bone meal, salt, and leather scraps; then solidly encased in wet clay. After clay dried, the pack was buried in hot embers for several hours, then allowed to air cool before opening.
  7. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Frank S (Apr 19, 2018), PJs (Apr 20, 2018)
    Oct 2017
    here in the USA brownells still sells their case harding compound, its just like kasenite,22$ a pound.do u guys have gunsmithing supply shop in UK ? they might carry it..surely some place in france will..
  9. The Following User Says Thank You to madokie For This Useful Post:
    PJs (Apr 20, 2018)
  10. #6
    ChrisB257's Avatar
    Dec 2016
    ChrisB257's Tools
    Yes, I remember Chris had mentioned his own method - in fact thinking back I seem to remember a mix of charcoal, salt and also - bone meal - was a usable formula. For sure the ferrocyanate does not sound too appealing!
    Ahh - see someone mentioned Brownells - had forgotten that.
    The Old Man's Shop
  11. #7
    Apr 2017
    UK
    Have been using this case hardening to harden the end of a replacement bolt for a small antique LAL tap wrench and it has worked really well
    The reward of repairing something that is so well designed is wonderful:
    More details of the case hardening compound – glue-it.com
  12. The Following 2 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Jon (Apr 9, 2020), Toolmaker51 (Apr 5, 2020)
