Results 1 to 4 of 4
Thread: Cheap Through Hole Lap
    jjr2001's Tools
    My little two cylinder steam engine model will need to have the cylinder lapped. I found these thru-hole-laps on eBay. Found some diamond grinding compound on the bay also. The lap 15/16 diameter was close enough to the 1" spec'd size for the piston and cylinder that I could not pass it up for about $6.00 with shipping included! However it was just the brass lap...Needed the support shaft and the tapered plug for expansion. Easy enough to turn and thread a 1/2-20 piece of steel for the shaft and then taper a piece of 1/2-20 all thread for the plug. Should work great and save me the time and brass for making the lap.
    Here is a great video by Suburban tool on through hole lapping:
    Don has a lot of excellent machining videos on the tube.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Cheap Through Hole Lap-img_1992a-copy.jpg   Cheap Through Hole Lap-img_1993a-copy.jpg
  2. The Following 6 Users Say Thank You to jjr2001 For This Useful Post:
    Frank S (May 27, 2018), NortonDommi (May 28, 2018), PJs (May 28, 2018), rossbotics (May 27, 2018), Seedtick (May 27, 2018), Toolmaker51 (May 28, 2018)
    I always enjoy watching Don's videos
    Good find on your brass laps
    jjr2001 (May 27, 2018), PJs (May 28, 2018)
    jjr2001's Tools
    Thanks Frank, I think Don is among the very best in making understandable videos for the shop.
    Cheers, JR
    Thanks jjr2001! We've added your Through Hole Lap to our Machining category,
  7. The Following User Says Thank You to DIYer For This Useful Post:
    jjr2001 (May 29, 2018)
