Results 1 to 5 of 5
Thread: Clip-on tire spikes for winter driving - GIF
    Clip-on tire spikes for winter driving. I will be the first to proclaim "gimmicky", but, in this case, I'm also skeptical of my skepticism. These look largely like tire chains, but perhaps easier to install. They have a variety of models with different attachment methods.
    2:43 video:
    More: Spikes-Spider: Easier, Better than Tire Chains - Winter Driving
    Estonian ice road and resonance wave destruction - video and photo
    NASA Tire Assault Vehicle (TAV), made from a German World War II tank model
    Tire doubling machine - GIF
    RingMaster large tire changer
    Removing bead wire from tire - GIF
    Machine for installing tires on rims - GIF
    Formula One tire warmers - GIF and photo
    Changing tire while driving - GIF
    PJs (Dec 11, 2018), ranald (Dec 28, 2018), Seedtick (Dec 10, 2018)
    Even though I live in Texas and it is the rare occasion that we see much if any snow. ICE maybe. However I carry a set of chains in my pickup for the just in case event.
    Most chains do little for ice and sometimes even make matters worse. This past weekend it rained a couple inches then we had 1/2" of sleet then 4 to 5 " of snow on top of that. A friend was in Lubbock TX where they got over 10". He called me up and said I see why you carry chains in the winter now, I'm stuck and can't get any traction.
    Are you in your pickup I asked.
    Yeah that's why I'm stuck.
    I told him to fill the bed of his truck about half full with snow and have his wife and kids pack it down while he was filling it. then just drive carefully.
    You see ICE weighs 57 lbs to the cubic foot and well packed snow can be close to 45 maybe 50 lbs if it is wet snow and packed tight enough. the bed of a full sized pickup can hold a couple thousand pounds of snow more than enough to give you traction.
    Anohter useful hack if you are one of those who have "O" ring tires on spoke rims and a rope is to wrap the rope through the rims around the tires tie it off to itself and you have just invented tire ropes.
    For ICE lower your tire pressure as much as you dare with out risk of sidewall damage pour some bleach on the tires and on the ground to get yourself going then drive at a steady slow speed. or dump some kitty litter on the ground in front of the tires drive at a safe slow speed.
    Dangerously under inflated tires should never be driven on for long periods of time but most tires can be ran around 10 to 15 PSI under inflated without lasting problems as long as you do so with common sense.
    PS the only time I have used my chains in recent years was in the summer time as mud chains
    bimmer1980 (Dec 11, 2018), KustomsbyKent (Dec 10, 2018)
    Supporting Member bimmer1980's Avatar
    Jan 2018
    bimmer1980's Tools
    Frank -- Interesting insights for gaining traction!
    What does the bleach do? I've only heard of using bleach at the drag strip to allow wheel spin up.....
    Quote Originally Posted by bimmer1980 View Post
    the bleach will wet the tires melting the ice just a little you could use antifreeze and do the same thing but antifreeze has an attractive odor and taste to animals. winterized windshield washer fluid will do the same thing, or alcohol but bleach in not attractive to animals
    You can even use hot water but depending on how cold it is the water may freeze before you get moving.
    the Kitty litter works best. The trick is use what you have to get just enough traction to begin moving
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    <source src="https://s3-us-west-1.amazonaws.com/hmt-forum/spider_clip_on_tire_spikes_for_snow.mp4" type="video/mp4">
    </video>
    2:43 video:
    http://www.homemadetools.net/forum/e...471#post122631
    http://www.homemadetools.net/forum/n...2755#post97064
    http://www.homemadetools.net/forum/t...683#post111218
    http://www.homemadetools.net/forum/r...9640#post89731
    http://www.homemadetools.net/forum/r...286#post116216
    http://www.homemadetools.net/forum/m...375#post116676
    http://www.homemadetools.net/forum/f...775#post118888
    http://www.homemadetools.net/forum/c...797#post119021
    Wonder if some crim/fool could try to counteract Police spikes with these. Sorry! didn't want to put ideas in young heads: some are spaced out enough, off the snow.
