Results 1 to 10 of 17
Thread: COMBINATION SKEW CHISEL & GOUGE
    Supporting Member morsa's Avatar
    morsa's Tools
    This tool, also called sjewji gouge or skewchigouge, has a combination of the cutting profiles of a skew chisel and a gouge, and hence is a multipurpose tool.
    The tools I show were made from a discarded printer 3/8” Ø steel bar, which had a reduced diameter to 1/4 "at both ends. The handles were made in pine and a brass ferule was added.
    This tool is based upon the article “Unconventional Tools” by John Siegel. It is possible to buy these tools in several commercial firms that sell woodturning supplies, and there are several homemade models on the net.
    morsa
  2. The Following 9 Users Say Thank You to morsa For This Useful Post:
    Altair (Aug 23, 2015), baja (Jun 11, 2020), Christophe Mineau (Aug 25, 2015), high-side (Jun 21, 2020), jere (Aug 24, 2015), Jon (Aug 22, 2015), kbalch (Aug 24, 2015), PJs (Aug 25, 2015), ranald (Apr 3, 2018)
    Altair's Avatar
    Fine looking tools you've got there, morsa. I should keep an eye out for printers the next time I hit the junk yard. Could use some of the drives and motors for future projects.
    Al
  4. The Following User Says Thank You to Altair For This Useful Post:
    PJs (Aug 25, 2015)
    morsa's Tools
    Thanks Altair.
    Unlike many of us who like to dismantle equipment and reuse component, the majority of people (usually not fond of tools, either bought or homemade), throw these devices when no longer work and require replacing. Therefore, another possibility to get free printer bars is to comment with family and friends; someone may even have some saved for several years and will appreciate that we remove this waste.
    I have read that with these step motors, we can make adaptations to CNC lathe or router, but this is beyond my comprehension.
    morsa
  6. The Following 2 Users Say Thank You to morsa For This Useful Post:
    Paul Jones (Aug 26, 2015), PJs (Aug 25, 2015)
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    Great looking gouges! Interesting profiles for the tips you have employed too. I have printer that likes to stop working and read low ink at the halfway mark. It will be perfect to try some of your ideas out with!
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks morsa! I've added your Combination Skew Chisel and Gouge to our Chisels category, as well as to your builder page: morsa's Homemade Tools. Your receipt:
  9. The Following User Says Thank You to kbalch For This Useful Post:
    morsa (Aug 24, 2015)
  10. #6
    morsa's Tools
    Thanks jere. With these tools is easy to cut beads and coves on spindle turning.
    You'd rather be sure your printer can't be repaired to avoid cannibalization of a potentially useful equipment; sooner or later you can get a really useless printer which can be dismantled without regrets.
  11. #7
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice re-purposing of the printer shafts Morsa. Really like the tool shapes, seem very versatile. Got lots of scraps like those and just getting to making a handle for my metal scrapers...hopefully I can turn them on my mini. Curious about your ferules...almost looks like there is a slot in the ferule end of the handle for clamping? Thanks for sharing another great build from re-purposed materials! ~PJ
    Mark Twain
  12. #8
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi Morsa,
    Same as my comrades above, great idea for the steel shaft reuse, what kind of steel do you think it is ? If you try to file it, will the teeth bite the steel ?
    Another question, why do you call it a skew gouge, I would have said scraper gouge ? Maybe I have not well understood the way you use it ?
    I have some round Hss left, I think I will try this shape as well.
    Thanks for showing !
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  13. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    PJs (Aug 27, 2015)
  14. #9
    morsa's Tools
    Thanks PJs.
    There is no slot in the ferrule nor in the handle. I use leftover plumbing brass nuts rounded at the Unimat lathe; once finished both elements, they are assembled by hand. Here is an amplificated picture:
  15. The Following User Says Thank You to morsa For This Useful Post:
    PJs (Aug 27, 2015)
  16. #10
    morsa's Tools
    Thanks Christophe Mineau
    Quote Originally Posted by Christophe Mineau View Post
    Christophe
    I don't know what kind of steel are these shafts, but they are really hard; the file does not bite them. For grinding, I proceed slowly and cooling with water in order to not alter the temper.
    I suppose it is called skew and gouge, more than because of the shape of the tool, because the way it cuts the wood, but to answer this question I refer to the article of John Siegel:
    http://www.bigtreetools.com/articles...ionalTools.pdf
    By the way, commercial houses that sell these tools also call them combination of skew and gouge.
  17. The Following User Says Thank You to morsa For This Useful Post:
    PJs (Aug 27, 2015)
