Remove advertisements
Results 1 to 4 of 4
Thread: Copper soft jaw faces for lathe chuck
    jjr2001's Avatar
    jjr2001's Tools
    I needed some soft jaws for my lathe and after seeing homeengineer's aluminum jaws:
    Aluminium soft jaws for the four-jaw chuck
    I decided to make some for two of my chucks. The first set was for the 3 jaw and has an added plate
    to protect the back of the part you are turning. Takes a bit more work but the added protection is worth it
    for some projects:
    Then on to the easy type. Just take some measurements and transfer them to paper. No measuring tools required, just use one of the jaws:
    Copper soft jaw faces for lathe chuck-img_1618b-copy.jpgCopper soft jaw faces for lathe chuck-img_1620b-copy.jpgCopper soft jaw faces for lathe chuck-img_1621b-copy.jpgCopper soft jaw faces for lathe chuck-img_1623b-copy.jpg
    Cut them out from copper sheet:
    Start the bending process:
    Copper soft jaw faces for lathe chuck-img_1631b-copy.jpgCopper soft jaw faces for lathe chuck-img_1633b-copy.jpgCopper soft jaw faces for lathe chuck-img_1634b-copy.jpgCopper soft jaw faces for lathe chuck-img_1635b-copy.jpgCopper soft jaw faces for lathe chuck-img_1636b-copy.jpg
    Then I always save a small poster board template for next time, and there will be a next time.
    Cheers, JR
  2. The Following 11 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (02-17-2018), Moby Duck (02-17-2018), olderdan (02-18-2018), Paul Jones (02-17-2018), piro222 (02-21-2018), PJs (02-17-2018), rlm98253 (02-17-2018), Seedtick (02-17-2018), thehomeengineer (02-17-2018), Toolmaker51 (02-17-2018), Tule (02-18-2018)
    thehomeengineer's Avatar
    Berkshire UK
    thehomeengineer's Tools
    Hi JR
    great idea to make the template. I will do the samething next time.
    The Home Engineer
    jjr2001's Avatar
    jjr2001's Tools
    Thanks Andy, the template is from my background in model aircraft. Multiple ribs etc require a simple template since so many are made and
    it is easy to just trace around the original. Same with broken parts. Just glue them together and make a template for laying out a new one.
    Cheers, JR
  5. The Following 3 Users Say Thank You to jjr2001 For This Useful Post:
    503dave (02-19-2018), Paul Jones (02-17-2018), PJs (02-17-2018)
    Content Editor DIYer's Avatar
    Thanks jjr2001! We've added your Chuck Soft Jaws to our Workholding category,
    Post your reply!
  7. The Following User Says Thank You to DIYer For This Useful Post:
    jjr2001 (02-21-2018)
