Free 50 Best Homemade Tools eBook:
Remove advertisements
Thread: Demagnetizer from transformer.
    olderdan's Avatar
    Devon UK
    olderdan's Tools
    Commercial versions of these can be quite expensive so here is a modified microwave transformer for demagnetising tools, there are more than one way do do this but the basic idea is to break the circuit of the laminated core and use the primary windings only.
    The top of the core can be removed completely along with the secondary windings to create what is known as an E core and inverted to use the bottom face as the usable surface.
    I have chosen to remove the secondary windings and make a saw cut though the top, I could have cut though the side but did not think of at the time, the cut is then filled with a non conducting material to prevent the ingress of anything that could bridge the gap, I did this because the mounting feet made it easier this way.
    Mine has a working surface of 90 x 70 and work is passed along the direction of the laminations to demag, it is important to make a slow pass and continue until about a foot away before switching of.
    A simple plywood box was made to the height of the core with a switch and warning light (the latter is not really necessary as it makes a rather loud buzzing noise when switched on).
    A thin top cover is used to prevent marking of finished work and would ideally be made of fibre but not having any I used sturdy cardboard (those beer boxes again) which has been varnished.
    I am sure this would overheat if left on but most things can be dealt with in under a minute.
    This can demag quite large items and if I have a HSS tool that needs treatment I just draw the whole tool holder over it.
    I have made a mini version for smaller items and this is often taken out to jobs outside the shop for drill bits etc.
  2. The Following 2 Users Say Thank You to olderdan For This Useful Post:
    PJs (01-09-2018), Seedtick (08-13-2017)
    mklotz mklotz's Avatar
    For those folks who may be intimidated by the idea of re-working a transformer...
    At garage sales and swap meets keep your eye peeled for bulk tape erasers, a fixture in the days of reel-to-reel tape recorders. I've used one for years for small tools and it's worked very well. I don't do Ebay but that might be a possible source too.
    Home Shop Freeware
    Content Editor DIYer's Avatar
    Thanks olderdan! We've added your Demagnetizer to our Miscellaneous category,
    Post your reply!
    Join 33,912 of us and get our 50 Must Read Homemade Tools eBook free.
