Depth gauge
This is the last tool I made, it's a depth gage.
It's a quite classical design, but a feature thing I wanted is to be able to lock the measure with a single hand.
That's why I put this large brass knob, so that I can turn it with the thumb, while holding the tool in my right hand, and possibly holding the piece I want to measure in the left hand.
http://www.labellenote.fr/file/homem...h_gauge_01.jpg
Here I am measuring the location of the tone holes on a flute that I made. I gauge the hole using the right drill bit, then measure with the depth gauge from the bottom up to the drill bit. Just need to add half the size of the bit to get the position of the axis.
Obviously, I need both hands to do that, hence the thumb knob.
http://www.labellenote.fr/file/homem...h_gauge_02.jpg
To get minimum friction of the rod in the body of the tool, I actually drilled the hole larger and put some boxwood bushes at both sides, so that it slides easily, but with no play.
http://www.labellenote.fr/file/homem...h_gauge_03.jpg
It's made out of oak, and the rod is a painted steel rod, salvaged from I don't remember what.
Nicely done, indeed. Re holding the measurement until you can lock it in, you might find the approach discussed here suggestive...
http://www.homemadetools.net/forum/d...7309#post36838
and once you've got the measurement locked into the gage, here's an easy way to read it accurately...
http://www.homemadetools.net/forum/d...7311#post36840
Thanks Christophe! We've added your Depth Gauge to our Height and Depth Gauges category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/depth-gauge-12"><img src="http://www.homemadetools.net/uploads/134806/depth-gauge-12.jpeg"
/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/depth-gauge-12">Depth Gauge</a>
<span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/depth-gauge">depth gauge</a></div>
</div>
</div>
</div>
