Change the harsh AC out put of your welding machine to the smooth DC current.
https://youtu.be/H-GEWaAJ6Rg
Thanks Polar Hunter! We've added your Welding Rectifier to our Electrical category,
as well as to your builder page: Polar Hunter's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/welding-rectifier"> <img src="/uploads/153236/welding-rectifier.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/welding-rectifier">Welding Rectifier</a> <span> by <a href="http://www.homemadetools.net/builder/Polar+Hunter">Polar Hunter</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/welding'>welding</a> </div> </div> </div> </div>
Great expalnation of this process! Do you know if the diodes can be doubled up or ganged? For example can 2 100 amp diodes be used to pass 200 amps? I would think 8 in a bank would work, just not real sure about it. Tahnks.
Muy bueno el conjunto Hunter similar al que fabriqué solamente que utilice 2 diodos de 260 Amp. y 1000 voltios se comporta excelente con electrodos comunes en aceros y en soldaduras de acero inoxidable, felicitaciones por el proyecto.
