Thread: DIY Riser Blocks (FREE PLANS)
    Supporting Member Downeast Thunder's Avatar
    Dec 2015
    usa
    Downeast Thunder's Tools
    DIY Riser Blocks (FREE PLANS)-img_0895.jpgDIY Riser Blocks (FREE PLANS)-img_0901.jpg
    FREE PLANS in pdf format (BOTH IMPERIAL & METRIC DIMENSIONS) – Download Info Below.
    Riser Blocks! Simple, yet effective. Here’s a fast, easy solution when you need to raise the height of a table, bench, bed, etc. I’ve included a free drawing for those wishing to have one, but it’s not really needed by most folks. The dimensions are whatever they need to be to adjust the height of whatever you’re raising to suit your needs.
    I used 5” x 5” White Cedar to make my riser blocks, but 4” x 4” would also work well. I simply used what I had on hand. The recess pocket I bored with a 1-1/8” Forstner bit is so the legs of the table would not slip off the blocks. You can choose whatever diameter bit size you need to suit your project. Note” I only bored about ˝” (12.7mm) into the wood.
    Here’s the link to the FREE (for conventional tools) PLANS download page (in both Imperial & Metric dimensions):
    https://www.downeastthunder.com/2019...ks-free-plans/
    Many thanks to all my subscribers for participating, commenting, liking, and sharing my videos. I very much appreciate your continued support of my YouTube channel. It’s a lot of fun for me, and I hope this trend continues.
    Here's the video:
    Downeast Thunder Creations
    http://www.downeastthunder.com
    Shoestring Shipyard
    http://www.shoestringshipyard.com
    Downeast Thunder Creations Youtube Channel
    https://www.youtube.com/channel/UCUU...pKFwXTYQ57ex3g
  2. #2
    Thanks Downeast Thunder! We've added your Riser Blocks to our Miscellaneous category,
    as well as to your builder page: Downeast Thunder's Homemade Tools. Your receipt:
