Art
I am sorry I even vented on this topic. A DRILL PRESS is made to drill holes NOT do MILLING.
I'M DONE
Art
I'M DONE
A drill press requires conversion to successfully function as a mill, that conversion must address The differences between a mill-drill and a drill press.
I looked at the location of the request Romania, and thought that the ability for access to Bridgeport mills etc. was limited, I also am totally aware of all the naysayers responses to modifying tooling for other purposes then there original intent. I totally agree that a drill press as originally designed cannot successfully function as a milling machine, but with the inclusion of a functional xy table and minor rigidity modifications, MT insert modifications any large drill press, (not a toy drill press) can be made equal to a round-column mill drill. The mill conversion that i show on that referred thread has less than $550.00 invested including the variable speed power supply and motor, xy table, bearing change, er 25 collet set, set of 1/8 to 3/4 2 and 4 flute endmills, DRO, 2.5" diameter3 cutter face mill, and is equal in its milling function to any round column mill, to exceed its functions would require a mill costing well over 4 times what I have into it. this forum is about how to do DIY tools.
art b
I agree 100% with master53yoda; throwing a x-y table on a drill press will not make a milling machine.
Completing mechanical upgrades like he suggest, minimize stability and rigidity issues. His use of terms "equal" and "exceed" recognize the difference perfectly.
Buy a HarborFreight Mini Mill. You can find 20-25% coupons and shipping is under $25...yes, under $25.
ALL the replacements parts are available from www.LittleMachineShop.com and they are really cheap.
Just took delivery of mine the other day. Got it all set up and it works SWEET!
They, and all the mini mills and lathes are made by Sieg in China. I bought my LMS 5100 7x16" High Torque lathe a couple months ago and it has worked flawlessly. I use the lathe about 98% of the time, the mill 2%, so I paid a premium for the better lathe.
Hi
I do some crude milling with my chinese drill press and a grizzly X:Y table.
Tramming is the big problem. Not rigid enough for heavy cuts.
Tramming the table is tough. The round table is held to the column with one bolt.
https://www.youtube.com/watch?v=NATR...ature=youtu.be
Thanks to all of you!
According to yours advises, I will put some money away and in at least one year, I will buy a milling machine. How about this one: Warco WM 14 Milling Machine - Quality Small Metalworking Mill ?
I am a beginner, but I have two right hands.
Thanks for all, machinists!
