Drill press mod
I have a big floor drill press in my shop but I don't have one in my "hobby workshop". So there was a bench drill press on offer at lidl and thought I should get one and make some improvements. This is the original model :
https://dl.dropboxusercontent.com/u/...dd6b58086e.jpg
The biggest problem with those bench models is the shallow throat. I build guitars as a hobby and i needed a big throat to be able to drill bridge post holes in body blanks. I used scrap pieces of square tubing for the construction. I drilled 4 holes at the back of the drill head and fixed it on the vertical tubing. I made the holes oversized on purpose, so that I could fine tune the alignment of the head in relation to the table. I moved the motor further back and got a matching belt to get it running. The table is just another piece of square tubing with an old cabinet door bolted on top. Finally, I made a bracket with welded steel plates so that the table can travel up and down. I used the original threaded handle to tighten the bracket on the vertical column.
Here's a photo with the original base in front for comparison :
https://dl.dropboxusercontent.com/u/...150223_005.jpg
Wao, that's a mod !
Congratulations !
I like it !
Christophe
Thanks immortalx! I've added your Drill Press Modification to our Drilling and Drill Presses category, as well as to your builder page: immortalx's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/drill-press-modification-6"><img src="/uploads/110852/drill-press-modification-6.jpeg" alt="Drill Press Modification" /></a> </div>
</div>
<div class="title">
<a href="/drill-press-modification-6">Drill Press Modification</a> <span> by <a href="/builder/immortalx">immortalx</a></span> </div>
<div class="tags">
tags:
<a href="/tag/drill-press">drill press</a>, <a href="/tag/modification">modification</a> </div>
</div>
</div>
</div>
WOWA thats some serious square tubing their partner....Great Mod now I have to clear my throat too..:lol:
I really like that mod!!! If only I could do that to my mill :headscratch: .
Great mod, and a very practical solution to your specific need.
Allow me to join the chorus in thanking you for the fine example of making something that was good better.
Pretty awesome mod you have there. I have a small Craftsman drill press that I have been trying to get to drill straight. Now I see your mod, and I may copy it to give me a bit more room while drilling. Thanks for posting your project.
Ron
