Because the cutter has to be sharp to follow fine detail, the finish will occasionally require a little sanding. If the template does not have fine detail, the cutter could be shaped with a small radius on the end.
Attached is a typical piece showing a very light sanding. It would require more finishing to be usable.
Thanks Guy Gadois ! We've added your Wood Lathe Duplicator to our Woodturning category,
as well as to your builder page: Guy Gadois 's Homemade Tools. Your receipt:
