Results 1 to 10 of 14
Thread: Electro-etching Metal Using a Stick On Label
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This video shows how I use salt water, a power supply, and a stick on label to mark aluminum and steel. This procedure should be done in a well-ventilated room or outside.
    Thanks,
    Rick
    Rick
  2. The Following 28 Users Say Thank You to rgsparber For This Useful Post:
    123pugsy (Mar 25, 2019), 12L14 (Jul 31, 2019), albertq (Yesterday), asterix (Jul 22, 2021), aussie (Jun 4, 2019), baja (Mar 25, 2019), Barend (Jun 6, 2019), bobs409 (Apr 1, 2019), Crusty (Jun 8, 2019), Dimitris Polychronis (Mar 24, 2019), enginepaul1 (Jul 22, 2021), FEM2008 (Jul 21, 2021), Floradawg (Oct 6, 2023), H.L (Dec 26, 2023), high-side (Mar 30, 2019), HobieDave (Mar 5, 2020), Inner (Mar 25, 2019), kboy0076 (Today), Ken Koch (Mar 30, 2019), mwmkravchenko (Mar 25, 2019), PowerMk (Apr 1, 2019), RetiredFAE (Jul 21, 2021), Scotsman Hosie (Mar 26, 2019), Seedtick (Mar 25, 2019), Tonyg (Mar 26, 2019), tuchie (Oct 6, 2023), Tule (Mar 26, 2019), walgui (Apr 1, 2019)
    Thanks rgsparber! We've added your Electro Etching Method to our Miscellaneous category,
    May 2018
    Polarity
    Thanks,
    Rick
    Hey Rick, I’ve tried doing this but I had my electrodes backwards. Would you say that that would make a difference or do you need to do it with them the way you did it. Also if you used a material specific electrolytes as your medium, do you think the results may be deeper or not?
    Thanks,
    Mike S.
  5. The Following User Says Thank You to Suttmike1 For This Useful Post:
    baja (Jun 5, 2019)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by Suttmike1 View Post
    Thanks,
    Mike S.
    Mike,
    The polarity is critical. The target metal must be positive relative to the salt water soaked Q-tip.
    I have not tried different electrolytes but would very interested to know of liquids that would cut deeper into aluminum and also steel.
    Rick
    Rick
    May 2018
    I do understand that in the commercial electric etching provides electrolytes for the base metal you are etching. I’ll get some and try it. It has to work better or why would they include them in the kits?? Thanks for the reply. I’ll switch my electrodes and see if that makes a difference for me. What voltage are you using and are you using a power supply or batteries?
    Thanks,
    Michael
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Thanks,
    Michael
    Michael,
    I'm using a 20V at up to 2 amps power supply. Be very careful using batteries that can put out more than that. For example, do not use a car battery.
    Rick
    Rick
  9. #7
    Dec 2016
    bobs409's Tools
    I'm going to try this! I have a vinyl cutter so making templates is a breeze!
    Thanks for sharing!
  10. #8
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Sounds very promising. Please keep us posted.
    Rick
  11. #9
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi rgsparber,
    I have tried different ways for the making of electrode.
    A good one for me it was a piece of stainless steel rod a spring from pen a piece from cigarette filter and pvc tape.
    But not the best, so later I replaced the filter with a piece of felt, which is more stable and has much longer lifetime before its polymerization begins.
    Electro-etching Metal Using a Stick On Label-electrode-s.jpg Electro-etching Metal Using a Stick On Label-felt.jpg Electro-etching Metal Using a Stick On Label-20160430_165226.jpg
  12. The Following 2 Users Say Thank You to kess For This Useful Post:
    enginepaul1 (Jul 22, 2021), high-side (Jun 5, 2019)
  13. #10
    aussie's Avatar
    Apr 2016
    If you can source AC after etching with DC it will darken the metal. In order to achieve this you would just have to run some wires of the transformer you are using prior to the diodes in your power supply.
