Results 1 to 4 of 4
Thread: Engine explodes on dyno - GIF and video
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (Jan 20, 2019), KustomsbyKent (Jan 19, 2019), oldpastit (Jan 20, 2019), PJs (Jan 22, 2019), Seedtick (Jan 19, 2019)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    This is the engine builder's explanation for the failure.
    We had just crossed 2200HP at 146psi when the 6.7L Cummins block simply couldn't handle the pressure and separated! We have done over 3000HP on this longblock setup so we feel like it was definitely a premature failure, but we see no signs of a problem in the datalog, pistons or rods before the block split. It looks as though the failure was simply stress fatigue to the OEM Cummins Block. The Longblock had been Modified by D&J Precision Machine with a Deckplate, 1" longer rods, ductile Iron Sleeves and 9/16" head studs, main studs and custom girdle, all which held up to the abuse had the block not failed. D&J has a new billet block in production stages that will hopefully prove to increase block strength significantly.
  4. The Following 3 Users Say Thank You to sossol For This Useful Post:
    Frank S (Jan 19, 2019), KustomsbyKent (Jan 19, 2019), PJs (Jan 22, 2019)
    Supporting Member toma's Avatar
    Serbia
    toma's Tools
    Machine is wiggling, repelling to die..!
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    Can’t make sense of the photographs in the video. It seems that they are a compilation of many other failures in addition to the original one. In some of the failures the crankshaft connecting rods and pistons remain connected to the dynamometer the initial failure that this video is supposed to represent it looked to me like the Pistons were thrown from the wreck and I could not tell if the crankshaft remained attached to the dynamometer.
