Results 1 to 10 of 11
Thread: Fixed drill press vise..
    Jyväskylä Finland
    Tuomas's Tools
    Found a broken drill press vise.
    After years of use, it finally was drilled full of dimples and it was cracked. End piece was missing, but it tought it can still be usefull.
    Fixed it by:
    Straightening the end with angle grinder.
    Then, filled dimples with my Telwin stick welder.
    Finally made new end to it by welding 15mm plate to it.
    Weld edges are chamfered, weld size is about A5.
    Before welding i preheated it to 150 deg of celsius.
    Welds are made using Esab OK 78.16 welding rod, 4mm and 144A.
    Then i stretched the welds by hammering.
    Finally wrapped it to insulantion wool, to cool it down slowly.
    Also made removable support to it.
    Now i can use it vertical or horizontal position.
    Great for holding objects when cutting or grinding with angle grinder, specially plates!
    But, works as a drill press vise too, or as a small press..
  2. The Following 12 Users Say Thank You to Tuomas For This Useful Post:
    Captn Roy (Aug 4, 2018), philipUsesWood&Brass (Aug 7, 2018), PJs (Jul 22, 2018), ranald (Feb 14, 2019), rgsparber (Jul 24, 2018), rlm98253 (Jul 23, 2018), rossbotics (Jul 24, 2018), Seedtick (Jul 23, 2018), sossol (Feb 16, 2019), Stevohdee (Jul 27, 2018), Toolmaker51 (Jul 25, 2018), Tule (Feb 15, 2019)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Great save Tuomas! Also like the vertical bracket idea...may use that one. Nice write up too! Although I don't know much about the welding rod the idea of preheat and cool down makes good sense and sure it will help others with this type of repairs.
    Thanks for sharing this with us.
    PJ
    Mark Twain
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Thanks mate.
    In this case. Preheating is necessary because mild steel cools down and also shrinks faster than cast steel. Heating, hammering and slowing cooling prevents joint to crack.
    I used tempilstik: Tempilstik® | Tempil
    To check the temperature before welding.
    Removed threaded rod and "slide", then heated the part in gas grill. Clamped the mild steel plate on its place and welded.
    I placed tack welds to the bottom, then welds to the top, removed clamps and welded sides. Finally bottom welds.
    Hammered all the welds and wrapped to insulation wool.
    When it was cooled down i cleaned the welds and removed splatters.
  5. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Jul 23, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks mate.
    Great blow by blow of the preheat and welding process, Thanks! Good way to minimize warpage. Have used temp sticks before when heat treating and tempering...nice product.
    PJ
    Mark Twain
  7. The Following User Says Thank You to PJs For This Useful Post:
    Tuomas (Jul 24, 2018)
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Yep. Those also seem to last forever. Foolproof and fast way.
    I usually use them at work. Before i weld next layer, i check that temperature of the joint haven't rised too high.
  9. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Jul 24, 2018)
  10. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Fixed it by:
    Good salvage, looks good too
    Doug
    Comments are always welcome
    Doug
  11. #7
    Thanks Tuomas! We've added your Drill Press Vise Restoration to our Vises category,
  12. #8
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by rossbotics View Post
    Doug
    Thank you Doug.
    I have idea for another kind of use for this, than just using as a vise .. tought that i could make ring roller adds to it. This kind of vise seems to fit nicely for that kind of use.
    That was the original reason to make that extra support.
  13. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Jul 25, 2018)
  14. #9
    Dec 2017
    NeiljohnUK's Tools
    Nice job, I wonder if the end was originally removed for direct clamping larger objects?
  15. #10
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by NeiljohnUK View Post
    It was drilled cut. Straight edge is where i shortened it by myself.
    I filled some holes with welds, but those sections we're too bad condition, that i decided to shorten it.
  16. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Nov 19, 2018)
