Results 1 to 10 of 16
Thread: Fly Cutter Attachment for Lathe Faceplate
    May 2014
    Del Mar, California
    Paul Jones's Tools
    A few years ago I first saw the design of this fly cutter attachment for faceplates in the book “The Shop Wisdom” by Rudy Kouhoupt. It looked like a great idea to try and it does machine very smooth surfaces. The cutter holder fits into one of my Unimat 2.7” dia. faceplates but the same idea could be applied to any lathe faceplate.
    I made the HSS cutter holding part from 0.50” x 0.625” x 0.75” cold rolled 1018 steel. There is a 0.17” deep step milled around all four sides on the backside to allow the fly cutter to fit snugly into one of the slots in the faceplate. This part is held in place with a 10-32 cap screw and two washers. The cutter was ground in a semi-circular form from an old 3/16” HSS drill shank and secured with a 6-32 set screw.
    The milled surface finishes created by the fly cutter are very smooth (almost mirror-like) and great for squaring blocks in preparation for other work. An added bonus is the faceplate can be used as an aide with a machinist square in setting up rectangular blocks at right angles to the cutter path (or set up to any other angle).
    Fly Cutter Attachment for Lathe Faceplate-unimat-faceplate-fly-cutter-backside.jpg
    Fly Cutter Attachment for Lathe Faceplate-unimat-faceplate-customer-fly-cutter-fits-slot.jpg
    Fly Cutter Attachment for Lathe Faceplate-unimat-faceplate-fly-cutting-action.jpg
    Thank you for looking,
    Paul Jones
    Last edited by Paul Jones; Dec 8, 2017 at 08:55 PM. Reason: Original photos missing and now replaced
  2. The Following 17 Users Say Thank You to Paul Jones For This Useful Post:
    baja (Jun 26, 2020), billster (Aug 14, 2018), Canobi (Apr 22, 2018), Captainleeward (Nov 26, 2017), Carnel (Jun 26, 2020), Christophe Mineau (Nov 3, 2014), Cogslayer (Aug 21, 2016), high-side (Aug 14, 2018), jjr2001 (Sep 1, 2016), kbalch (Nov 3, 2014), Moby Duck (Aug 13, 2018), olderdan (Nov 29, 2017), PJs (Aug 15, 2018), saintrain (Aug 15, 2018), Sleykin (Jun 26, 2020), Tonyg (Jun 26, 2020), Toolmaker51 (Apr 21, 2018)
    Nice post, another idea to add to this group's collective knowledge.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Paul! I've added your Lathe Faceplate Fly Cutter Attachment to our Machining category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
  5. The Following User Says Thank You to kbalch For This Useful Post:
    Paul Jones (Nov 3, 2014)
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Very good adaptation .. Thanks for sharing.
    Sorry my mistakes in english.
  7. The Following User Says Thank You to Hotz For This Useful Post:
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Since originally posting this article about the 3" swing Unimat fly cutter three years ago I discovered the original photos disappeared and have now been replaced.
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    I just purchased a Lathe/Mill combination and the first thing I seem to need is a fly cutter.
    Still recovering from the cost of all the tools and measuring goodies I find this an brilliant idea, only problem is I did not receive a face plate with my machine.
    Now my question can I take a 3" disk and clamp it in the chuck and use it as the face plate or will the side forces damage my chuck?
    Is the cutter hispeed steel? How is the cutting edge ground?
  10. #7
    I don't think you need to worry about chuck damage.
    You really don't need a disk to convert the chuck into a monster fly cutter. A length of steel, fitted with a spigot to grip in the 3jaw or gripped directly in a 4jaw will work just fine. Drill a hole in the bar to accept the tool holder (or a slot if you want adjustable radius). The tool holder can be cobbled together from a bolt and nut as I did here...
    http://www.homemadetools.net/forum/i...y-cutter-58399
    Depending on the stiffness of the steel and desired depth of cut, you may want to fix things so the back of the tool holder seats against the face of the chuck to make things more rigid.
    Many years ago I made what I'm describing here. I'll try to find it and get a picture to make my description more understandable.
    Home Shop Freeware
  11. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    baja (Jun 26, 2020), Tonyg (Jun 26, 2020)
  12. #8
    OK, I managed to find the tool I mentioned. I wrote a description which can be found here...
    http://www.homemadetools.net/forum/f...943#post102905
    I've reproduced the two photos from that post below. They may be self-explanatory...
    Home Shop Freeware
  13. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    garage nut (Nov 27, 2017), Paul Jones (Nov 26, 2017), Tonyg (Jun 26, 2020)
  14. #9
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    What shape should the cutter be ground to?
  15. #10
    I've always had good results with a generous radius on the tool. Probably the profiles suggested for lathe tools will work well as a starting point. Experiment a bit and see what works for you.
    With a tool like this you'll want to keep the depth-of-cut small and the feed slow. It's meant to clean up a surface, not take off large amounts of material, a process better done with endmills.
    Home Shop Freeware
