Results 1 to 10 of 10
Thread: Gear repair
    Supporting Member Vyacheslav.Nevolya's Avatar
    Dec 2015
    Ukraine
    Vyacheslav.Nevolya's Tools
    Gear repair
    Hi. Sometimes it's a very unpleasant situation when it's impossible to quickly find a new gear. I decided to restore the gear, maybe this is not the best way, but for some time it should work.
    I weld a damaged tooth with an electric arc welding
    Then after 10-15 minutes of working with this tool)))
    Result. The gear is almost new
  2. The Following 24 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Andyt (Jun 22, 2018), billster (Feb 24, 2018), clydeman (Oct 20, 2020), Duke_of_URL (Oct 21, 2020), EnginePaul (Oct 21, 2023), greyhoundollie (Oct 18, 2018), katy (Oct 21, 2020), lassab999 (Oct 21, 2020), LMMasterMariner (Jun 24, 2017), mwmkravchenko (Oct 19, 2018), NortonDommi (Jun 21, 2018), nova_robotics (Oct 20, 2020), Okapi (Jan 18, 2019), olderdan (Jun 23, 2017), Papa Bill (Jun 22, 2018), Paul Jones (Jun 24, 2017), rgsparber (Feb 24, 2018), rlm98253 (Jun 21, 2018), Seedtick (Jun 23, 2017), sossol (Feb 25, 2018), stainless stål (Jun 25, 2017), tonyfoale (Feb 25, 2018), Toolmaker51 (Jun 21, 2018), volodar (Jun 22, 2018)
    olderdan's Tools
    Another brilliant exercise in resourcefulness, well done.
    I would be interested in why such robust gears got damaged, I seem to remember they were from a motorcycle gearbox.
    Regards
    Olderdan
    Good job, nothing wrong with the method.
    I used to have to sit for hours and sometimes more than 2 or 3 days at time building up the worn teeth on 3 and 4 ft diameter gears for oil field equipment then spend days as in several hand grinding the profiles of the very large teeth to some semblance of what I thought the original profile should be. A 150 lb 20 tooth pinion gear was bad enough but the 2000 lb ring gear for a 30" rotary table meant a minimum of 100 lbs of electrodes
  5. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    greyhoundollie (Oct 18, 2018), NortonDommi (Jun 21, 2018), Paul Jones (Jun 24, 2017), PJs (Jun 22, 2018), volodar (Jun 22, 2018)
    May 2013
    Whoa! ---Joe
    Dec 2015
    Ukraine
    Olderdan
    Gears from a motorcycle and a car. The reason for the breakage is very simple, There was a nut in the gearbox, it hit the tooth and locked the gears.
  8. The Following 6 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    greyhoundollie (Oct 18, 2018), mwmkravchenko (Oct 19, 2018), olderdan (Jun 24, 2017), Papa Smurf (Jun 26, 2017), Paul Jones (Jun 24, 2017), PJs (Jun 22, 2018)
    Thanks Vyacheslav.Nevolya! We've added your Gear Repair Method to our Miscellaneous category,
    as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
  10. #7
    May 2015
    Very nice work.
  11. #8
    Feb 2018
    Years ago I had a steering gear in a collector I.H. Cub tractor with a broken tooth. This was before I had a welder etc. Took it to a machine shop and that was how they fixed it. It outlasted the rest of the tractor.
  12. The Following User Says Thank You to VinnieL For This Useful Post:
  13. #9
    Dec 2016
    Vyacheslav, I have done a similar repair job on a big lathe years ago. But friend, I have to tell you, that you are a recycling sorcerer! You can turn a sows ear into a silk purse. I have worked with Russians and Ukrainians and you people are some of the most resourceful people I have ever met!
  14. #10
    Oct 2016
    old kodger's Tools
    I also have played this gig, one tooth missing on the main drive gear of an 8 foot gillotine, 3 feet in diameter and 4 inches wide, cast steel, the teeth were half inch thick at the root so i drilled and tapped a row of holes , screwed in mid tempered (grade 5) bolts welded them all together then reprofiled the tooth. I heard from another employee that it was still working long after I left the company
  15. The Following User Says Thank You to old kodger For This Useful Post:
    bigtrev8xl (Oct 21, 2020)
