Thread: Gears Chucking Tool
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Gears Chucking Tool
    This tool is needed for workholding of gears in lathe chuck if you need
    to do some machining like boring bigger hole or cutting keyway. It's much
    easier to make it from pipe than to make it from round bar. Still have
    to make 30T gear holder from round bar, as I don't have pipe from which
    I can make it. Plenty free of charge materials as shown in pictures.
    All these gears; 2 x 24 T, 1 x 26 T, 3 x 30T, 1 x 36T, 2 x 45T, 1 x 54T,
    3 x 55T, 3 x 60T, 1 x 70T and 2 x 72T will be used in my present project
    'lathe headstock external gearbox'. Need to bore them for 20 mm shafts and
    to cut 6 mm keyways. Beside the gears I also bought HSS square cutting tools
    (HRC 66 - 69) for cutting keyways, 4, 5, 6, 8, 10 and 12 mm, 6 x 6 mm keys,
    oil level sight windows and even balls for shifters handles. Will have the
    following spindle speeds: 25, 50, 75, 100, 150, 202, 225, 300, 404, 450, 606,
    675, 808, 900, 1212, 1350, 2423 and 2700, but more about this project once
    completed. In picture 3 is shown tool which I made for machining 44T gear
    which is mounted on my lathe spindle (picture 4).
    Best regards
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails Gears Chucking Tool-1.jpg   Gears Chucking Tool-2.jpg   Gears Chucking Tool-3.jpg   Gears Chucking Tool-4.jpg   Gears Chucking Tool-5.jpg
    Gears Chucking Tool-6.jpg   Gears Chucking Tool-7.jpg   Gears Chucking Tool-8.jpg   Gears Chucking Tool-9.jpg   Gears Chucking Tool-10.jpg
    Gears Chucking Tool-00.jpg   Gears Chucking Tool-11.jpg   Gears Chucking Tool-12.jpg   Gears Chucking Tool-13.jpg
  2. The Following 14 Users Say Thank You to LMMasterMariner For This Useful Post:
    Andyt (Jan 2, 2020), baja (Jan 1, 2020), Canobi (Apr 17, 2018), Captainleeward (Nov 23, 2017), dwbachor (Nov 28, 2017), HobieDave (Apr 12, 2020), Jon (Nov 20, 2017), kboy0076 (Nov 4, 2023), NortonDommi (Nov 21, 2017), olderdan (Nov 20, 2017), Paul Jones (Nov 22, 2017), PJs (Apr 18, 2018), Seedtick (Nov 20, 2017), Toolmaker51 (Apr 17, 2018)
    Thanks LMMasterMariner! We've added your Gear Chucking Tools to our Machining category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
