Results 1 to 9 of 9
Thread: Giant vise
    Nov 2015
    Italy
    rendoman's Tools
    Giant vise
    Hi all!
    I just found this little beast!
    There are no marks of brand, the weight is pretty high, I used all my strenght to lift from ground to table
    The conditions seems very good, there are two marks of carelessness, the threaded rod is in perfect shape.
    My milling machine is tiny, I could Mount on the table for short time. I'm thinking about using this vise on the bench or a dedicated support as a normal big vise.
    230mm width x 250 stroke
    Any advice welcome
    Giant vise-dsc05436_1600x1200.jpg Giant vise-dsc05446_1600x1200.jpg Giant vise-dsc05450_1600x1200.jpg
  2. The Following 8 Users Say Thank You to rendoman For This Useful Post:
    baja (Apr 19, 2019), Clockguy (Apr 18, 2019), Drew1966 (Apr 20, 2019), greyhoundollie (Apr 18, 2019), high-side (Apr 19, 2019), IAMSatisfied (Apr 18, 2019), Scotsman Hosie (Apr 19, 2019), Seedtick (Apr 18, 2019)
    Jul 2016
    Possibly used with a planer, it is a bit large for a small mill.
    Jul 2016
    In your middle picture with the vice in end, that would be my choice for use. Making knife blades, sharpening mower blades etc. Great complement to the bench vice you have. Great find.
    Eric
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    Wow — nice find! (Now just don't drop it on 'yer foot.)
    Now that's a vise! The serrated jaws and nut on the moving side tell me it is cam operated jaw. The screw gets size close, the operator locks material with a simple motion. With the flat sides it can be mounted vertically too; that is not very common.
    In shot with caliper for scale, about an 8" 200mm opening, an roughly as wide. And jaws are removable, for soft jaws, fixtures and other convenient workholding.
  7. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    rendoman (Jan 20, 2021), Scotsman Hosie (Apr 21, 2019)
    Sep 2012
    Hinchinbrook QLD
    Is the cam action any more or less secure than tightening all the way with the screw?
    ..... nut on the moving side tell me it is cam operated jaw. The screw gets size close, the operator locks material with a simple motion. ....
    Or is this just for ease of operation on multiple same size parts?
  9. #7
    Quote Originally Posted by 12bolts View Post
    Is the cam action any more or less secure than tightening all the way with the screw?Or is this just for ease of operation on multiple same size parts?
    Yes. If it is actually a cam operated vise. You adjust clamping size [screw] on like sized material, to where jaw isn't contacting to switch workpieces. Cams usually impart .020-.030 movement, sometimes more.
    One variation has a serrated nut. The moving jaw bolts on.
  10. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    12bolts (Apr 22, 2019), Scotsman Hosie (Apr 21, 2019)
  11. #8
    Feb 2019
    Funny, I just stumbled on this post from a google search. I have one of that exact vise made by Hartford Special Machine Co.
    I occasionally use it on my milling machine.
  12. #9
    Nov 2015
    Italy
    rendoman's Tools
    Thank you all for the posts!
    Unluckily it seems that I havn't received notification for this post in the past
