Finally completed power feed for my mill/drill.
https://www.youtube.com/watch?v=5QAs...25350rk0h00410
Cheers
LMMasterMariner
Cheers
LMMasterMariner
Additional info
PWM Controller
9-50V 40A DC Motor Speed Control PWM RC Controller 12V 24V 48V 2000W MAX
can be found at
https://www.aliexpress.com/item/9-50...5bc57f6927jZ1J
Cheers
LMMasterMariner
Great Job LMMasterMariner
Lot of engineering went into that as I can very well see, should last you a good bit, thanks for sharing
Doug
Solid build LMMasterMariner, as you have left the hand wheel in place I assume you can still use it independently of your drive.
Absolutely beautiful piece of work. Tell me though, is there to be anything else available except a video showing a bunch of photos showing tightening bolts, cutting stock, and milling parts? Like a set of drawings?:idea:
I'd love to replicate something similar.
Thanks for sharing!! :beer:
Walkman,
Thanks for sharing!! doesn't count. Don't forget to click on 'Thanks' button. Drawings to follow.
Cheers LMMasterMariner
And here is the drawing.
I surmise limitation of window motor is not only too little power [torque & amps] but having it's own gear reduction, RPM too slow for converting up into usable feed rate? The fan motor has all kinds of RPM so your gearbox puts out super reduction needed for milling, not just moving X axis putting here to there.
I'm not surprised, recalling that 18 speed gearbox you hung on the lathe. You have power transmission down-pat!
All along I thought your shop was onboard a vessel...until I saw hinged windows and plaster.
Too funny.
Thanks LMMasterMariner! We've added your Milling Machine Power Feed to our Milling category,
as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-milling-machine-power-feed-2"> <img src="/uploads/221372/homemade-milling-machine-power-feed-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-milling-machine-power-feed-2">Milling Machine Power Feed</a> <span> by <a href="http://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/mill'>mill</a>, <a href='http://www.homemadetools.net/tag/power-feed'>power feed</a> </div> </div> </div> </div>
