Results 1 to 10 of 11
Thread: Heavy Duty Power Feed for Milling Machine
    LMMasterMariner's Avatar
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Finally completed power feed for my mill/drill.
    Cheers
    LMMasterMariner
  2. The Following 14 Users Say Thank You to LMMasterMariner For This Useful Post:
    Bummers (Oct 13, 2023), Captainleeward (Mar 4, 2019), daddytroll (Apr 2, 2022), Jon (Feb 20, 2019), mr mikey (Oct 14, 2023), olderdan (Feb 21, 2019), Ralphxyz (Mar 31, 2021), rarmintrout (Apr 1, 2021), rossbotics (Feb 21, 2019), SA MAKER (Feb 25, 2019), Seedtick (Feb 21, 2019), tonyfoale (Apr 1, 2021), Toolmaker51 (Feb 22, 2019), Tule (Feb 22, 2019)
    Jan 2016
    Dubrovnik - Croatia
    Additional info
    PWM Controller
    9-50V 40A DC Motor Speed Control PWM RC Controller 12V 24V 48V 2000W MAX
    can be found at
    https://www.aliexpress.com/item/9-50...5bc57f6927jZ1J
    Cheers
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails Heavy Duty Power Feed for Milling Machine-powerfeed-pwm-controller.jpg
    Dec 2013
    Florida
    rossbotics's Tools
    Great Job LMMasterMariner
    Lot of engineering went into that as I can very well see, should last you a good bit, thanks for sharing
    Doug
    Comments are always welcome
    Doug
    olderdan's Tools
    Solid build LMMasterMariner, as you have left the hand wheel in place I assume you can still use it independently of your drive.
    Jan 2016
    Dubrovnik - Croatia
    Hello Olderdan, you are correct. I can still operate it manually, even when power feed is engaged. It's little bit harder, there is some resistance, but I can do it.
    Walkman's Avatar
    Sep 2018
    Absolutely beautiful piece of work. Tell me though, is there to be anything else available except a video showing a bunch of photos showing tightening bolts, cutting stock, and milling parts? Like a set of drawings?
    I'd love to replicate something similar.
    Thanks for sharing!!
  8. #7
    Jan 2016
    Dubrovnik - Croatia
    Walkman,
    Thanks for sharing!! doesn't count. Don't forget to click on 'Thanks' button. Drawings to follow.
    Cheers LMMasterMariner
  9. #8
    Jan 2016
    Dubrovnik - Croatia
    And here is the drawing.
    Attached Files Attached Files
  10. #9
    I surmise limitation of window motor is not only too little power [torque & amps] but having it's own gear reduction, RPM too slow for converting up into usable feed rate? The fan motor has all kinds of RPM so your gearbox puts out super reduction needed for milling, not just moving X axis putting here to there.
    I'm not surprised, recalling that 18 speed gearbox you hung on the lathe. You have power transmission down-pat!
    All along I thought your shop was onboard a vessel...until I saw hinged windows and plaster.
    Too funny.
  11. #10
    Thanks LMMasterMariner! We've added your Milling Machine Power Feed to our Milling category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
