Free 50 Best Homemade Tools eBook:
Remove advertisements
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    olderdan's Avatar
    UK
    Home made handee tool
    This is made almost entirely from an old uPVC window hinge and a piece of all thread.
    Took about 1 hour to make, its not pretty but it works, cost me nothing and its only going to get chucked into my toolbox.
  2. The Following 8 Users Say Thank You to olderdan For This Useful Post:
    Jon (05-15-2017), LMMasterMariner (05-17-2017), Paul Jones (05-16-2017), rossbotics (05-16-2017), Seedtick (05-15-2017), Toolmaker51 (05-15-2017), Trojan Horse (05-16-2017), Tule (05-16-2017)
    Ralphxyz's Avatar
    Dec 2016
    That's great, the first of many I am sure.
    I will even make one eventually, it certainly seems handy!!
    Ralph
  4. The Following User Says Thank You to Ralphxyz For This Useful Post:
    olderdan (05-16-2017)
    Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    saw this the other day and said that has to go to the bottom of my todo list, then today I needed it for hold a nut to mount under my luggage rack that is close to the body on my buggy. would have saved cramped fingers. although a long nose vice grip plier would have worked but it was late and I was not thinking to good.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
  6. The Following User Says Thank You to Ed ke6bnl For This Useful Post:
    mklotz mklotz's Avatar
    Quote Originally Posted by Ed ke6bnl View Post
    Yardstick + double-sided carpet tape
    Home Shop Freeware
  8. The Following 5 Users Say Thank You to mklotz For This Useful Post:
    Frank S (05-15-2017), grandviewdoug (05-16-2017), Paul Jones (05-16-2017), Toolmaker51 (05-15-2017), Trojan Horse (05-16-2017)
    rossbotics rossbotics's Avatar
    Dec 2013
    Lady Lake, Fl
    Pretty clever Marv, I like it
    Comments are always welcome
    Doug
  10. The Following User Says Thank You to rossbotics For This Useful Post:
  11. #6
    Content Editor DIYer's Avatar
    Thanks olderdan! We've added your Handee Tool to our Miscellaneous category,
  12. The Following User Says Thank You to DIYer For This Useful Post:
  13. #7
    Quote Originally Posted by rossbotics View Post
    If you don't have carpet tape on hand, wind duct tape onto the stick with the sticky side outward. Keeping carpet tape around is a good idea though; I've machined small parts by attaching them to a faceplate with the stuff.
    If carpet tape is too aggressive in the nut-holding scenario simply stick a magnet on the tape and hold the nut with the magnet.
    Wooden paint stirrers, often given away at paint stores, can substitute for the yardstick if one only needs a shorter reach.
    Home Shop Freeware
  14. #8
    May 2016
    Great idea! Thanks for the share. I've used a piece of flat metal with a hobby magnet or a piece of wood with double sided tape.
  15. #9
    Frank S's Avatar
    Using yard sticks , paint stirs and soda straws with sticky tape is a great quick fix solution to a seldom encountered problem, that often times hardly warrants buying or making a more permanent tool.
    Not exactly the same thing but back when I was modifying D10 caterpillar blades I had to make several cuts as far as 5 ft deep inside of the blade to do this I clamped the torch handle to a broom handle then screwed an eyelet into the wood and tied a small cable to the cut lever then through the eyelet back to where I could pull on the cable to depress the lever worked great and I didn't have to spend over $1000.00 for a specialized demolition torch like those used by scrapers at the metal recycling places.
  16. #10
    Since folks seem to have liked my yardstick/carpet tape third hand, here's another hint along the same lines to add to your arsenal...
    I always keep a pair of wooden chopsticks in my tool bag(s). While long forceps, e.g.,
    https://www.amazon.com/Dissekt-Rite-...ywords=forceps
    are handy as a shirt pocket, chopsticks have certain advantages over them...
    Cheap, often free if you eat lots of Asian food
    Don't conduct heat or electricity and can't be magnetized
    Can be shaped into job-specific shapes with a sharp knife
    Pieces can be sliced off to shim wood screws in an overly large hole
    If you're not confident wielding chopsticks, get a couple of chopstick helpers...
    https://www.amazon.com/Inteliventor-...27s+chopsticks
    which will allow you to make your chopsticks work like conventional forceps.
    Home Shop Freeware
  17. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Moby Duck (05-19-2017), Toolmaker51 (05-21-2017)
