Awesome work!
LMMasterMariner (May 5, 2018)
Your gearbox, entire development, and presentation gets my vote for "Tool of the Week". Forever!
Benefits from recirculating oil are probably suited to equipment with long run cycles, where baths aerate lubricants to unhappy plain bearings.
Bath oiling works perfectly satisfactory. Suits many gear forms including hypoid and spherical or roller bearings.
I've noticed some work better, where the engineering provides 'paths' for oil to reach components above the fluid level.
Rotating gears transfer oil upward readily, even at slow speeds. Slingers [oil knives] are common in small engines.
Shafts grooved with a shallow long pitched helix generate lengthwise travel. Most are rounded, not vee'd grooves.
Oil wicks [capillaries] are very effective; cotton cord or pipe cleaners wrapped loosely around light gauge stiff wire. Position these over oil ports of bearing housings. About the first boxed gear train I worked on included small balconies; reservoirs to better feed remote capillaries.
Frank S (May 6, 2018), LMMasterMariner (May 5, 2018), PJs (May 7, 2018)
LMMasterMariner (May 14, 2018)
Update / Upgrade
In order to upgrade this gearbox and make an overkill, I have alredy ordered and received 2 gears; 33 and 55 teeth.
Paid total 3.73 USD for both of them. Picture of speed chart together with new gears attached.
I also decided to install recirculating pump and prevent "churning".
Will buy recirculating pump together with tank, pumping capacity 1.2 liters per minute. Price up to 25 USD max.
Picture attached.
Google translated from Chinese:
Taiwan genuine 1.2L liters / 1.8 liters electric lubricant pump / CNC electromagnetic pump / machine automatic oil pump
It can be found on the following web pages:
https://item.taobao.com/item.htm?spm...cket=12#detail
Will also buy 2 distributors for copper pipes; each 8 lines and will have 8 lines for gears and 8 lines for 8 bearings.
Picture attached.
B type adjustable resistance proportional distributor / TK oil distributor / oil / oil valve / lubrication branch
Picture attached and it can be found at the following web pages: Check the prices.......
https://item.taobao.com/item.htm?spm...id=44406509307
Best regards
LMMasterMariner
Jon (May 15, 2018)
Recently bought 33 and 55 teeth gears from taobao at China.
https://item.taobao.com/item.htm?spm...cket=15#detail
Prices are for Chinese market. The same can be found at aliexpress but prices are much higher.
Best regards
LMMasterMariner
I must say this is one impressive build!!
What is the idea behind the adjustable bearing flanges? Is it to overcome layout precision or to allow slightly different center diameters in the gear sets? Frankly in all my years in industrial maintenance I’ve never seen such flange mounted bearings.
One item worth consideration is the output belt. You will have a lot of torque capability on that belt. As a result you may get slippage or even a broken belt. Something to consider.
hello wizard69,
the only reason for these adjustable pillow blocks was that I found them cheap and idea was that I could adjust the gap between gears very easily. (which I actually did, but it wasn't easy). gap can also be properly adjusted using ordinary bearings and will use 6203 bearings for my new gearbox.
cheers
lmmastermariner
seb fontana (Nov 24, 2018)
