I joined this forum to to say thank you for this design and making the pattern available for others to use. This will work perfect for my garden tractor I am building. The factory hood hinge set up is useless and this will allow me to tilt the hood up and out without hitting the grille. I am interested in how you would put the gas struts on it and what size. Thank you again, Richie
Is there any reason other than style/looks, that the bars are curved? couldn't this be done with straight bars? thanks
Mark
I found your scissor hinge on a google search. I'm attempting to duplicate it to lift the hatch on my sailboat, but I'm running into a problem. On a car hood there's very little or no overlap. On a boat hatch there's an overlap of probably an inch. I've been able pretty much duplicate your design, but I can't figure out how to get the lift before the swing. Was wondering if you can aid me with your CAD magic :-)
Thank you
Lowell ... Southern California
Check out this Linkage page for some simple explanations.
https://technologystudent.com/cams/link1.htm
Jeedub57
Hi Lowell,
I can try! I will need some dimensions from you though. Length of the hatch, the depth of the flange and how much clearance there is between the flange and the hatch opening. Once I have those I think I can reconfigure the pivot points to get what you need.
Mark
Mark
Thank you for your prompt response. I'll get measurements in the next couple days.
Lowell
Jeedub57 ... cool link to watch but can I build my own stuff on the site?
