How to make a Hose Clamp wire binding Tool
https://www.youtube.com/watch?v=iY67WDjFMsk
i hope that was not brass or copper wire i saw u using,, it would be too soft and loosen,,steel wire only..
Looks like rusty tie wire to me.
I did not find a normal thread so I used the thread I found just for the video and chill out everything fine friends
Well done DIYfixman. Nice video and robust tool for use!
Nice work diyfixman , I did one a while ago, heres what I did , next one I make I will weld a 3/8 or 1/2_drive socket on the end of spinning split pin.
Thanks diyfixman! We've added your Clamp Wire Binding Tool to our Fastening category,
as well as to your builder page: diyfixman's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-clamp-wire-binding-tool"> <img src="/uploads/220787/homemade-clamp-wire-binding-tool.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-clamp-wire-binding-tool">Clamp Wire Binding Tool</a> <span> by <a href="http://www.homemadetools.net/builder/diyfixman">diyfixman</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/clamp'>clamp</a>, <a href='http://www.homemadetools.net/tag/hand-tools'>hand tools</a> </div> </div> </div> </div>
Thanks peter_351! We've added your Wire Clamp Tool to our Fastening category,
as well as to your builder page: peter_351's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-wire-clamp-tool-9"> <img src="/uploads/220792/homemade-wire-clamp-tool-9.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-wire-clamp-tool-9">Wire Clamp Tool</a> <span> by <a href="http://www.homemadetools.net/builder/peter_351">peter_351</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/clamp'>clamp</a>, <a href='http://www.homemadetools.net/tag/hand-tools'>hand tools</a> </div> </div> </div> </div>
Looking at all the tools and ways to do this, I'm bothered about the waste of so much wire. A few here and there , not an issue. But more and more it just becomes pure waste. I have many times wrapped wire around a few times and then just twist the wire together till its snug. Never had a leak or failure with very little wire used.
I made one like this several years ago. The wasted wire does "hurt" my sensitivity to waste. However that is sometimes over powered by the desire to have a clean, tight, secure, nice looking clamp. Due to the wasted wire, about the only place I use it replace ends on air or water hoses. You do have to make sure you get those sharp ends tucked in really well!!!
I do save the "wasted" wire ends. I tell myself that someday I will get a TIG welder. They will make good filler for stainless steel projects.
Or they can be used as you mentioned by just wrapping with a twist to secure it.
