Results 1 to 4 of 4
Thread: Hydraulic rocker stud puller
    Sep 2013
    athomp's Tools
    Problem: Pulling pressed-in rocker studs from cylinder heads. The usual way to do it is put a spacer block over the stud and tighten a nut down on it until the stud pulls out. But if a stud needs to be replaced it's because the threads are stripped or it's broken off and there are no threads so the usually way doesn't work. To solve this problem I made a hydraulic stud puller utilizing a Porta-Power Pull-back Ram. Now I just need to put a nut on the stud and pull. If the stud is stripped or broken I just weld a nut on it.
  2. The Following 5 Users Say Thank You to athomp For This Useful Post:
    123pugsy (Feb 17, 2019), J.Pierce (Apr 29, 2022), nashty1 (Feb 18, 2019), Scotty1 (Feb 18, 2019), that_other_guy (Feb 20, 2019)
    Thanks athomp! We've added your Rocker Stud Puller to our Engine category,
    as well as to your builder page: athomp's Homemade Tools. Your receipt:
    Aug 2018
    that_other_guy's Tools
    Great tool idea!
    Two questions:
    1) how do you know if the stud are threaded or press fit (to chose the right tool for the job)?
    2) how does this tool grab the nut?
    Thanks!
    Brian
    Sep 2013
    athomp's Tools
    Quote Originally Posted by that_other_guy View Post
    Great tool idea!
    Two questions:
    Thanks!
    Brian
    1. Two ways to do that: put Vise-Grips on and see if it turns. The other way I have found that is quicker is to hit them with a hammer - the press-in studs can be driven in a bit while the screw-in studs won't move (and they sound different when you hit them).
    2. The bottom of the part that attaches to the ram has a slot that is the size of the stud (smaller than the nut).
  6. The Following User Says Thank You to athomp For This Useful Post:
