Results 1 to 5 of 5
Thread: Improvised deep throat calipers
    The typical six or eight inch calipers don't have jaws deep enough to measure large objects. Fortunately, it's easy to improvise a deep jaw caliper using things commonly found in many shops.
    Almost everyone has a combination square. If you're lucky enough to have two, you can remove the head from one, attach it to the other, and voila, deep jaw calipers.
    If you don't have two squares, but have the protractor head for your square, you can use that to form the second jaw. Just be sure to square it against the combination head before making your measurement.
    Even if you have two heads and the protractor head, I highly recommend the Hi-Gage Square Attachment. In addition to being useful as a caliper jaw...
    it has many other uses, some of which are pictured here...
    Lee Valley Tools - Hi-Gage Square Attachment
    You can buy it here (standard disclaimer applies)...
    Hi-Gage Square Attachment - Garrett Wade
    but shop around - that may not be the best price.
    Home Shop Freeware
  2. The Following 5 Users Say Thank You to mklotz For This Useful Post:
    baja (Sep 14, 2019), C-Bag (Jul 23, 2016), EnginePaul (Sep 15, 2019), Jon (Jul 25, 2016), PJs (Jul 25, 2016)
    Thanks mklotz! We've added your Deep Throat Calipers to our Calipers category,
    May 2013
    Marv, just wow! Thanks for this nugget!
    Quote Originally Posted by j.bickley View Post
    You're very welcome.
    If you have a metalworking shop with a surface plate and a height gauge, you can often use those to imitate a large capacity, though not necessarily deep throat, calipers. The problem arises if the part to be measured can't be brought to the surface plate. That's where these improvised calipers come into their own.
    Not the accuracy of a micrometer but most parts that big don't need to be measured with micrometric accuracy. A pi tape will give good accuracy for smooth round parts but is no help on other shapes.
    Home Shop Freeware
    Supporting Member gatz's Avatar
    gatz's Tools
    that's great idea
    always been a problem with 6 or 8" calipers
