Free 50 Best Homemade Tools eBook:
Remove advertisements
    Captainleeward's Avatar
    Jul 2014
    San DIEGO, California
    Index Plate Handle Modification Grizzly G1049 Rotary Table.
    First I want to thank Mike Zam at youtube for his modification which is similar to mine but not the same.
    The reason for this modification is, that it is very hard to pull the spring loaded handle
    while turning the handle .
    Using a small piece of sheet metal with a hole drilled in one end and bent twice at the proper
    length and making the modifications I did you can rotate the handle without having to
    maintain a pulling force on the handle.
    See all photos below.
    Also note that I used a parting tool to create a slot on the handle for the sheet metal end to ride in. I also filed a flat in the handle for the bolt to tighten against.
    Index Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-008.jpgIndex Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-010.jpgIndex Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-011.jpgIndex Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-012.jpgIndex Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-013.jpgIndex Plate Handle Modification Grizzly G1049 Rotary Table.-motorized-lead-screw-014.jpg
  2. The Following 2 Users Say Thank You to Captainleeward For This Useful Post:
    Paul Jones (12-11-2017), Seedtick (12-12-2017)
    Content Editor DIYer's Avatar
    Thanks Captainleeward! We've added your Index Plate Handle Modification to our Miscellaneous category,
    Post your reply!
    Join 20,941 of us and get our 50 Must Read Homemade Tools eBook free.
