Results 1 to 8 of 8
Thread: Knife making Vise
    benny_chapman's Avatar
    benny_chapman's Tools
    Knife making Vise
    Finally got around to making a knife vise on the weekend. Cost around $20 in materials. Was dead simple, cant believe I had not done it sooner. Clamps blade in, rotates in two planes. 50mm NB heavy wall pipe slide into square tube (65mmx2mm). Took about an hour. I used 22mm quarter round wood, glued and pinned to half round as it was way cheaper than 45mm round and I didn't have a band saw to split it. An aluminium strip protects the wood, I should have used steel but didnt have anything ready to go, had the aluminium left over from another project. May need to replace it over time but it doesnt need much force to hold a blade so should last a while.
  2. The Following 13 Users Say Thank You to benny_chapman For This Useful Post:
    Andyt (Aug 17, 2018), HobieDave (Mar 19, 2020), Jon (Aug 16, 2018), Moby Duck (Aug 16, 2018), MountainMan (Aug 17, 2018), PJs (Aug 16, 2018), rossbotics (Aug 16, 2018), Seedtick (Aug 16, 2018), thoms_here (Sep 12, 2023), Tonyg (Dec 8, 2018), tuchie (Sep 7, 2023), Tuomas (Aug 16, 2018), wolfpaak (Aug 17, 2018)
    Great way to safely secure the blade while working on the tang.
    Jyväskylä Finland
    Tuomas's Tools
    That's clever. And very usefull too.
    Apr 2017
    Nice! Now I just have to determine if it can be done with *(#&)*^! American-dimensioned stuff. :-(
    (I'm sure it CAN - question is whether it works as well, fits snugly enough, etc.)
    It wont be hard to find, I am pretty sure the 50mm NB (Nominal Bore, in other words, closeISH) heavy pipe is actually 2", it is around 51mm. You dont need heavy wall round pipe if you weld a nut on, I just went heavy to tap it directly and the heavy was a nice fit into the square. The fit in the square pipe is not critical, although mine is a very nice fit (around 1mm clearance, I needed to file the weld seam), the locking bolt being at a corner will push any smaller size into the opposite corner holding it snugly either way.
    Supporting Member MountainMan's Avatar
    Jul 2018
    Conway,SC
    MountainMan's Tools
    Great work man!! You've inspired me to finally breakdown and build the vise I have been needing to make for over a year now. I had wood jaws in my bench vise and always have to keep repositioning it. So now I know what im doing this weekend. Thanks for the motivation!!
    Dave
    "I have not failed...I've just found 10,000 ways that wont work"
    Thomas Edison
  8. #7
    Supporting Member high-side's Avatar
    Jun 2018
    ACinSV ,
    That's no biggie...
    Just write on the back of your calculator in your shop: 1 mm = .03937 in. or 1 in. = 25.4 mm
    Pretty soon you will remember it and won't need the reference.
    Pat
  9. #8
    Thanks benny_chapman! We've added your Knife Vise to our Knife Making category,
    as well as to your builder page: benny_chapman's Homemade Tools. Your receipt:
