Results 1 to 10 of 12
Thread: Large holes on the drill press
    Supporting Member Vyacheslav.Nevolya's Avatar
    Dec 2015
    Ukraine
    Vyacheslav.Nevolya's Tools
    Sometimes you may need to make a hole large diameter. The usual drill was not done, so that's made a this device.
    Large holes on the drill press-1.jpg Large holes on the drill press-2.jpg Large holes on the drill press-11012014643.jpg Large holes on the drill press-11012014646.jpg Large holes on the drill press-11012014648.jpg
  2. The Following 9 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Andyt (Oct 2, 2019), baja (Oct 2, 2019), chevy75 (Jan 21, 2017), DIYer (Jan 21, 2017), Marc Broussard (Feb 21, 2017), Moby Duck (Jan 23, 2017), rlm98253 (Jan 23, 2017), toma (Feb 11, 2018), Toolmaker51 (Jan 22, 2017)
    Fly cutters are handy to have around
    Thanks Vyacheslav.Nevolya! We've added your Drill Press Large Hole Cutter to our Drilling and Drill Presses category,
    as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
    Trepanning is alive and well! Simple expedient for large holes in material of substantial thickness. Even thin material trepans, if clamped with a 'retainer' above. Sometimes the hole is not what you are after, it's the washer...Much like the difference between slug and blank in diework.
    When possible, I trepan material thinner than depth of correct size drill point angle. It also compensates for insufficient machine size, or excessive RPM to spin correct size bit.
    Works great in lathes too. Just prepare for a slug that temporarily has a mind of it's own.
    "Works great in lathes too. Just prepare for a slug that temporarily has a mind of it's own."
    Yeah a Saturday morning cartoon always comes to mind when that happens
    Ping,ping ,piiiing Ricochet rabbit, and the razor sharp edge is like a chakram, it will slice through anything in its path unitl the kinetic energy dissipates
  7. The Following User Says Thank You to Frank S For This Useful Post:
    Marc Broussard (Apr 16, 2017)
    New Lenox, IL
    garycullen's Tools
    Did you drill a hole in the material first to allow for the center to go into? Looks like a handy tool, good job!
  9. #7
    Marc Broussard's Avatar
    Jan 2017
    Groton Ma.
    Marc Broussard's Tools
    Hi Vyacheslav. Great idea, solid results. A maker's goal. It looks like shop material construction. Must be a carbide cutter I assume. How did you get the square hole in the round stock?
  10. #8
    Dec 2015
    Ukraine
    Quote Originally Posted by garycullen View Post
    First you need to drill a central hole
  11. #9
    Dec 2015
    Ukraine
    Quote Originally Posted by Marc Broussard View Post
    Hi. The store sells a carbide cutter for ceramic tiles. There's too much carbide plate, if properly sharpen it would also cut the metal. Sorry. My English is not perfect, I did not understand your question "How did you get the square hole in the round stock".
  12. #10
    Jan 2017
    Groton Ma.
    Thanks for your reply to my poorly phrased question. I figured out how to get a square cutter into a round hole. Grind the cutter shank round. I guess I was asking how you cut a square hole to receive the cutter which I assumed (and looks) was square. The ones I have all are square. The shaft that holds yours looks round. My mortising machine don't do steel. If I wanted to make this tool how would I get a square hole to hold my square cutter in that round stock? Ignore this if I'm not making any sense. I'm a woodworker. I have three fly cutters. All have a square hole to hold the cutter. How do I make that hole?
