4 Attachment(s)
Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design
Well ok, I only made 4 adjustable stops for mine. However the number is unlimited due to the cartridge design.
The two main blocks were milled from hot rolled that I had on hand.
The gate was made with the same.
Cartridges are made of 1018 1/2" x 1/2" square stock which was also in stock.
The hot rolled was milled to .700" thick for both the main block and the spacer block.
The gate is spring loaded with a belleville washer which is nothing more than a flat spring in the form of a washer.
Two long 1/4-20 cap screws hold it together and to the lathe. Had to drill two holes and tap them in the lathe bed.
One 8-32 thumb screw for each cartridge to lock in the adjustment.
Note: The cartridges are threaded internally for about 3/4" for the all thread so the thumbscrew just locks in the adjustment.
The tail end is opened up to 17/64" for a bit of added clearance for the threaded rod that does not need to engage the threads.
Short rods are just standard all thread and the black ones are grade 8.
Advantages:
Unlimited number of stops. Adjustments can be saved if making multiple parts.
No interference with anything. The carriage is free to move wherever.
The lathe chuck will not hit it like with the type that mounts to the ways.
I have over 2.4" of adjustment with each rod and if I wanted more I could drill another mounting hole and move the main block
toward the tail stock. That could reduce the ability of the tool bit to reach the chuck. Depends on how far down I relocate the main block.
Cheers, JR
