Remove advertisements
Results 1 to 6 of 6
Thread: Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design
    jjr2001's Avatar
    jjr2001's Tools
    Well ok, I only made 4 adjustable stops for mine. However the number is unlimited due to the cartridge design.
    The two main blocks were milled from hot rolled that I had on hand.
    The gate was made with the same.
    Cartridges are made of 1018 1/2" x 1/2" square stock which was also in stock.
    The hot rolled was milled to .700" thick for both the main block and the spacer block.
    The gate is spring loaded with a belleville washer which is nothing more than a flat spring in the form of a washer.
    Two long 1/4-20 cap screws hold it together and to the lathe. Had to drill two holes and tap them in the lathe bed.
    One 8-32 thumb screw for each cartridge to lock in the adjustment.
    Note: The cartridges are threaded internally for about 3/4" for the all thread so the thumbscrew just locks in the adjustment.
    The tail end is opened up to 17/64" for a bit of added clearance for the threaded rod that does not need to engage the threads.
    Short rods are just standard all thread and the black ones are grade 8.
    Advantages:
    Unlimited number of stops. Adjustments can be saved if making multiple parts.
    No interference with anything. The carriage is free to move wherever.
    The lathe chuck will not hit it like with the type that mounts to the ways.
    I have over 2.4" of adjustment with each rod and if I wanted more I could drill another mounting hole and move the main block
    toward the tail stock. That could reduce the ability of the tool bit to reach the chuck. Depends on how far down I relocate the main block.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design-img_1641b-copy.jpg   Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design-img_1642b-copy.jpg   Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design-img_1638b-copy.jpg   Lathe Carriage Stop Multiple with unlimited number of stops. Cartridge Design-img_1640b-copy.jpg
  2. The Following 8 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (02-21-2018), LMMasterMariner (02-22-2018), mklotz (02-21-2018), olderdan (02-21-2018), Paul Jones (02-22-2018), PJs (02-21-2018), Seedtick (02-21-2018), thehomeengineer (02-21-2018)
    olderdan's Avatar
    Devon UK
    olderdan's Tools
    Nice original thinking, I like it.
  4. The Following User Says Thank You to olderdan For This Useful Post:
    jjr2001 (02-21-2018)
    jjr2001's Avatar
    jjr2001's Tools
    Thanks Dan, I had the idea after using two separate stops to make a part. One was on the left and the other on the right of the carriage.
    That setup limited carriage travel to a small amount. I almost made a turret type buy I already had noticed that my current stop would get in the
    way of the chuck jaws if they were opened very long. ( I have a 5" chuck on this little lathe).
    The turret type would limit me to 4 or maybe 5 stops and would work ok if mounted below the ways but became complicated when using it for long reaches.
    So this is what I ended up with. Just the evolution of my thinking.
    My other two stops are posted here:
    Mini Lathe Carriage Stops Micrometer and Screw
    Still plan on using them when required.
    Cheers, JR
  6. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (02-21-2018)
    Content Editor DIYer's Avatar
    Thanks jjr2001! We've added your Lathe Carriage Stop to our Lathe Accessories category,
    jjr2001 (02-22-2018)
    Paul Jones's Avatar
    May 2014
    Del Mar, California
    Paul Jones's Tools
    JR,
    That is a very good design for allowing multiple stops when you have limited space on your lathe. Also you put a nice fine finish on the parts. Looks good.
    Thank you for the ideas.
    Paul
  10. The Following User Says Thank You to Paul Jones For This Useful Post:
  11. #6
    jjr2001's Avatar
    jjr2001's Tools
    Thanks Paul, I think it is going to be just the ticket for making multiple complex parts on the lathe.
    Should also be quite useful for making a single part with several features that need to be "indexed".
    Cheers, JR
    Post your reply!
