Hi Aphilipmarcou,
Thank you for the compliment. I use an import scissor-type clamp-on knurling tool that bought from Enco years ago and have modified and improved it by removing all the "slop" out of the tool. I also added a feature that makes it easier to tighten the knurling tool by hand and most of the time do not need to use a wrench to tighten the knurling tool (see
http://www.homemadetools.net/forum/k...7860#post24656 ). Using the feel by hand makes for more consistent knurling when using around 150 to 240 RPM and a feed rate of 0.008" IPR and plenty of lubrication (not cutting) oil when working with 303 stainless steel. It usually takes two passes, one to the left and a return to the right to produce a sharp knurl.
A good example is some of the kitchen tools I made (see
http://www.homemadetools.net/forum/s...3072#post77395 ). I also use a brass brush along the top knurling wheel to remove any flakes of steel that sometimes come off from the knurling process and this prevents the flakes from being embedded back into the surface finish. I always pre-machine the part diameters to the correct diameter dimension by calculating this by hand or using the Android phone app "Knurling Calculator" and typically make the part 0.001" to 0.002" larger than the suggested diameter. It is better to be slightly larger on the diameter than smaller.
I hope this helps to explain the knurling process I use on steels. The most difficult knurling for me is when working with brass and the best advice is to use a flood coolant or a Noga Cool Mist system to quickly remove the brass flakes produced when knurling brass.
Regards,
Paul Jones
